97 Ford Mustang - Mustang Evolution
Old 06-15-2013, 09:15 PM   #1
97 Ford Mustang
My 97 Mustang will not crank. At first the lights would come on now it won't do anything at all. No lights, horn, and it will not click. Please help ASAP!!! Thank you very much.
caulderk is offline   Reply With Quote
Old 06-15-2013, 09:17 PM   #2
Ubnbit's Avatar
Have u tried the battery? Check the terminals? Jump it off? What all have u done/not done?
Old 06-15-2013, 10:20 PM   #3
I did. After about 2 1/2 hours it cranked. I think there is an electrical problem. Do you know anyone in Charleston SC that specializes in electrical problems? Thanks.
Old 06-15-2013, 10:25 PM   #4
Ubnbit's Avatar
Not a clue. Somebody else might.
Check all the fuses. Look for wires bare that are touching, check the ground cable to see if its loose.
Old 06-15-2013, 10:29 PM   #5
I will do that.
Old 06-15-2013, 10:50 PM   #6
Kevo91's Avatar
Region: Utah
Its either your battery or alternator is bad. Jump it if you need to, get a volt meter and put it on the terminals, if it reads less than 13 at idle its your battery. If it reads over 13 but goes down at 2k rpms its your alt. Also check the back top of the alternator, there are these 2 cables that plug in and they are famous for coming unplugged
---------- Post added at 10:50 PM ---------- Previous post was at 10:46 PM ----------
Or if you dont have a volt meter autozone can test them for free
Kevo91 is offline   Reply With Quote
06:48 PM
