Bogging at WOT? - Mustang Evolution
Old 06-16-2013, 05:46 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
Bogging at WOT?
1 gear 5k (shift), 2 gear 5k (shift), 3 gear 4k Boggs... Kinda feels like a rev limiter bog.. Like I press the gass and nothing.. Kinda cuts in and out, when second.. No codes, I got beat buy a v6 firebird because of this help!!!!
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 06-16-2013, 06:28 PM   #2
I got pretty much the same thing going on. What I plan on doing...clean MAF, then replace spark plugs, and check all vacuum hoses. After that if nothing changes I will change the cops.
If that doesn't fix, I'll be at a loss.
I'm running the Torque App on my phone and can definitely tell something is up, I need to data log everything and see if something sticks out.
Old 06-16-2013, 06:34 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
I did plugs, fuel filter about a month ago.. I only have 19lbs injectors but with only intake and exhaust I can't see how I'd be making them out..
2001 GT - True Blue
Old 06-16-2013, 06:39 PM   #4
Doubt your maxing them out, could be injectors are clogged or maybe fuel pump is I the way out.
I'll be data logging mine to see if anything noticeable pops out at me.
Old 06-16-2013, 07:11 PM   #5
slow281
sixpac's Avatar
Region: Nebraska
It just sucks.. I hate cat and mouse stuff
2001 GT - True Blue
Old 06-16-2013, 08:39 PM   #6
slow281
sixpac's Avatar
Region: Nebraska
HELP! now it's not doing it.. Sat for about an hour rained and the temp outside went down 20 but I also put gass in.. My last fill up was with BP gas.. So maybe bad gass? Or fuel pump got weak when hot..
2001 GT - True Blue
Old 06-16-2013, 09:55 PM   #7
Count Dragula's Avatar
I had a similar issue an thought it was the fuel pump and turned out to be a bad coil on plug. It started bogging like that and then got worse and worse until it misfired all the time
---------- Post added at 11:55 PM ---------- Previous post was at 11:54 PM ----------
Mine would run fine until it the motor warmed up and then run like crap and bog out
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-16-2013, 10:46 PM   #8
slow281
sixpac's Avatar
Region: Nebraska
But I just drove it 75 miles and nothing..
2001 GT - True Blue
Old 06-16-2013, 10:57 PM   #9
How many miles are on your car? Do you regularly run it down below a quarter tank? How much fuel was in the tank when this occurred? It sounds like a fuel delivery issue...
Old 06-16-2013, 11:42 PM   #10
slow281
sixpac's Avatar
Region: Nebraska
82k not usually.. New filter and plugs..
---------- Post added at 12:42 AM ---------- Previous post was at 12:42 AM ----------
Btw 1/4-1/2
2001 GT - True Blue
Old 06-17-2013, 12:19 AM   #11
When you said that you filled up after, I was kinda thinking that you may have been starving the pump while you were banging through the gears there Hot Rod, but nothing you said leads me to believe that. I've had similar symptoms from a weak fuel pump but it is accompanied by some bucking also. Like its running out of fuel at high RPM. Never hurts to check the fuel pressure. Tomorrow some more knowledgeable guys will chime in and get this squared away. ..
Old 06-17-2013, 06:00 AM   #12
My COPs went bad at 79,000 and gave me every symptom of a fuel pump. Only occurred when gas was below a 1/4 first and then got worse. It may not be that could be a bad fuel pump also. Could be a fuel filter also. Change the cheap stuff first
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-17-2013, 09:51 AM   #13
2000 Mustang Gt's Avatar
This is the problem I'm having right now. I thought my fuel pump was bad and I almost ordered a fuel pump but then I went to get the code checked and they told me it was probably my cop's. I ordered them and should get them Thursday.
2000 Mustang Gt is offline   Reply With Quote
Old 06-17-2013, 10:01 AM   #14
slow281
sixpac's Avatar
Region: Nebraska
I've changed plugs and fuel filter..
---------- Post added at 11:01 AM ---------- Previous post was at 11:00 AM ----------
I have no codes computer reads clean as day..
2001 GT - True Blue
Old 06-17-2013, 10:10 AM   #15
My did too man. COP are different than plugs... I swore up and down it was the pump and another mustang guy told me to change these and it literally fixed everything
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-17-2013, 10:14 AM   #16
slow281
sixpac's Avatar
Region: Nebraska
I might its easy to change them there just not cheap..
2001 GT - True Blue
Old 06-17-2013, 10:27 AM   #17
I changed fuel filter and spark plugs already so I hope this does the trick!
Old 06-17-2013, 10:34 AM   #18
Yeah my intake busted and coolant got everywhere so I think that's what made mine go bad. I think the coolant got in the COP of cylinder 1
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-17-2013, 10:46 AM   #19
slow281
sixpac's Avatar
Region: Nebraska
Did that no help
---------- Post added at 11:46 AM ---------- Previous post was at 11:45 AM ----------
I'm ordering from advance auto.. After 4 order and 4 promo codes I will come to a total of 342 for all 8 cop
2001 GT - True Blue
Old 06-17-2013, 12:17 PM   #20
slow281
sixpac's Avatar
Region: Nebraska
What fuel pump should I get if I'm gonna pick one up
2001 GT - True Blue
Old 06-17-2013, 01:13 PM   #21
Walbor( forgive my spelling) 255. It's good up to like 500 horsepower. I have an extra that only had 20,000 miles on it
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-17-2013, 05:34 PM   #22
slow281
sixpac's Avatar
Region: Nebraska
How much you want for it.. I think ima do cops, injectors, and pump..
2001 GT - True Blue
Old 06-17-2013, 05:53 PM   #23
Ok I did some data logging today. It appears my short term fuel trim readings are way off.
First they are no where near close to each other and bank 1 seems to always run low, like 0 to -20.
I think this is giving me a false rich.
However it's not throwing any codes.
Anyone have any experience with this?
I did a little research online, I'm leaving towards a possible bad O2...Anyone else have thoughts
Old 06-17-2013, 06:09 PM   #24
It's literally just the pump. It doesn't come with everything in that kit so probably like 100. I think it's 200 something new.
Edit: Actually they are 100 new and I would rather hold it since I can't get much out if it.
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-18-2013, 11:16 AM   #25
slow281
sixpac's Avatar
Region: Nebraska
Been driving for 3 days just fine now.. I'm still gonna look into a pump and new cops
2001 GT - True Blue
Old 06-18-2013, 11:17 AM   #26
I drove mine for almost 5,000 miles just fine and then I started acting up again and finally misfired and bogged all the time. Shifter handle was going crazy when motor was under a load
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-18-2013, 11:19 AM   #27
slow281
sixpac's Avatar
Region: Nebraska
Mine kinda does that from a stop..
2001 GT - True Blue
Old 06-18-2013, 11:37 AM   #28
Dang can you hear it misfiring at idle?
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-18-2013, 11:59 AM   #29
slow281
sixpac's Avatar
Region: Nebraska
Nope purs like a cat.. I think it's my cable/quadrant
2001 GT - True Blue
07:23 AM
