Brake Question - Mustang Evolution
Old 06-18-2013, 07:11 AM   #1
Tanker2012's Avatar
Brake Question
I just upgraded my suspension in the rear with new upper/lower control arms, prothane bushings, H&R lowering springs, new shocks/struts and everything is working great. While I had it apart, I took apart my brakes and paired the calipers. When I put it back together I added new pads and rotors.
Like I said everything is working great but now I think they're a a problem with my right rear brake. I believe that the emergency cable may be too tight as the parking brake light comes on randomly as I drive. Also, the brake is getting super hot and smoking unlike the other side. Finally, one of the expandable locating pins on the caliper bracket has seized I believe.
Two questions:
1) how can you free a seized locating pin? I lubed and tried to get it to spin and compress and it's stuck
2) can you adjust a parking brake cable? If so where is the adjustment located.
Thanks all.
ID:	114578   Click image for larger version
Tanker2012 is offline   Reply With Quote
Old 06-18-2013, 11:36 AM   #2
BigB227's Avatar
Had same problem on my rear right caliper and I had to get a whole new caliper and fixed all the problems
BigB227 is offline   Reply With Quote
Old 06-18-2013, 12:19 PM   #3
Tanker2012's Avatar
I figured as much. I already ordered a set of red powder-coated OEM remanufactured calipers. They were only $59 ea and come with the carrier brackets.
Thanks for your feedback.
Old 06-18-2013, 12:22 PM   #4
Slow4V's Avatar
GTs have a common problem with the rear locking up and you have to replace it.
Did my buddy's and his was damaged ..
Nice setup
Old 06-18-2013, 12:25 PM   #5
Tanker2012's Avatar
Thanks. I started my mods with braking and suspension. I am now ready for more power (once I install the replacement rear calipers I just ordered today).
I appreciate your input. I didn't know that was common.
Thanks.
05:28 AM
