Superchargers - Mustang Evolution
Old 06-20-2013, 02:12 AM   #1
Warbot's Avatar
Sure this has been answered a thousand times but i cant find much on low hp builds with the vortech v3. I just want like 360-400hp and was thinking about trying to get the complete kit with injectors,fuel pump and bypass valve. Most threads seem to be for the most power and i just want it reliable because it will be my daily driver for years to come. Im wondering if i would need anything else to safely run that much hp? and how much roughly does a dyno tune typically run? Also is it reliable or should i just not bother with spending 4000$ for more problems down the road. Thanks for any input! Oh and keep in mind this is the non innercooler kit.
Warbot is offline   Reply With Quote
Old 06-20-2013, 07:16 AM   #2
BigB227's Avatar
Ok if you plan on jut putting on the stock bottom end it'll "maintain" to about 400-425 hp some people get lucky and have a good engine and some don't its all a Russian roulette. You'll have people tell you they've ran a supercharger on a stock engine for years no prob and some other have the opposite. At the least I'd buy upgraded fuel injectors and fuel pump to handle the extra hp. I personally don't know about the included fuel management from them but I'd rather do it right, but in the end it's all your call and for a dyno run to tune your vehicle expect about $600+ depending one difficulty to dial in your tune and all
BigB227 is offline   Reply With Quote
Old 06-20-2013, 07:25 AM   #3
AgentOrange's Avatar
Having the right (professional dyno) tune is going to play a huge role in how long your stock motor lasts. I wouldn't bet against the supplied injectors and pump from Vortech, but I'd consider it necessary to find the best tuner in your area and fork out the money for a real-deal tune.
AgentOrange is offline   Reply With Quote
Old 06-20-2013, 08:00 AM   #4
67mustang97's Avatar
Region: Vermont
I had full bolt ons with methanol and a V3 it made 356 rwhp
Old 06-20-2013, 08:13 AM   #5
BigB227's Avatar
Like I said I've had no real experience with their fuel management so I don't know if they are good or not
Old 06-20-2013, 10:12 AM   #6
Warbot's Avatar
What psi were you running?
---------- Post added at 11:12 AM ---------- Previous post was at 11:11 AM ----------
Okay so what if i ran like 360hp? Would that be safe do you think?
Old 06-20-2013, 10:30 AM   #7
BigB227's Avatar
360 would seem like a safe number for a stock engine and like someone said the tune is the number one factor you need to ensure reliability
Old 06-20-2013, 10:33 AM   #8
Region: Vermont
10 psi with a safe 93 octane tune.
Old 06-20-2013, 10:33 AM   #9
Warbot's Avatar
Oh okay and yeah ive been researching the midwest and it seems like a guy up by kansas city is the best here just going off hear say. If you guys got any others you would reccomend in missouri or just outside i would appreciate it. Trying to figure out if i want to gamble 4000$ haha its a bigger thing than i thought it would be.
Old 06-20-2013, 10:35 AM   #10
BigB227's Avatar
Yeah I started diving into the FI world and drew up a build list for the future. Right now I'm running about $18-20K. But that includes engine,fuel,suspension,brakes, and transmission.
Old 06-20-2013, 02:13 PM   #11
Warbot's Avatar
Thats so much! But it would be a perfect car and awesome, im just looking for cheap hp but not to much where i have to change a ton of stuff.
Old 06-20-2013, 02:18 PM   #12
Warbot's Avatar
Also looks like they come with 38lb injectors but doesnt say about the pump.
Old 06-20-2013, 06:43 PM   #13
BigB227's Avatar
Yeah it will be perfect for me but yeah I'm not sure about the pump that comes with the kit
Old 06-20-2013, 09:59 PM   #14
2002VertGT's Avatar
From what I've been talking to people about my procharger kit...it's best to have 42lb injectors (100-150used) 255lph fuel pump at least....300 to be safe. And a 90mm lightning maf. Get the v3 put all that on and tune it
4.10 Gear/RPM thread
Old 06-22-2013, 06:34 AM   #15
Warbot's Avatar
Ah okay, seems like everyone gets the lightning maf must be good.
Old 06-22-2013, 07:32 AM   #16
Region: Vermont
Once you install the lightning maf you need to ad a air intake temp sensor. You'll need to cut 2 wires on the factory harness I think they are the 2 outside wires but double check me because it's been a few years since I did it.
Old 06-22-2013, 08:19 AM   #17
Warbot's Avatar
Thanks for the input man still deciding if i should do it or not haha.
Old 06-22-2013, 12:19 PM   #18
BigB227's Avatar
What about the SCT MAF??? Do they require the same cutting an splicing??
Old 06-22-2013, 12:54 PM   #19
MidnightBlueGT's Avatar
All in the tune
Old 06-22-2013, 01:18 PM   #20
2002VertGT's Avatar
If you can afford it get the slot style maf and the tube to hold it. I forget the brand. But it's like 300$ for the combo. That will allow for future power if you want to crank it up. The lightning maf will do you good though if you don't want massive hp.
Old 06-22-2013, 01:25 PM   #21
Region: Vermont
I didn't have a sensor when I got my car tuned so he gave me 2 tunes one without the sensor to keep my engine light off and a tune for when I got a sensor. The sensor is in the stock maf and the lightning maf doesn't have it not sure about the SCT.
Old 06-22-2013, 05:25 PM   #22
Warbot's Avatar
Yeah i would be okay with like 360rwhp considering im running almost bone stock on performance upgrades need to get exhaust first for sure. Sure that would be a pretty big difference in power haha but you always want more!
Old 06-22-2013, 06:53 PM   #23
Region: Vermont
Headers off road H or X pipe with a cat back system. CAI pulleys and a tune will get you about 250-260 rwhp. So you car will make right around 300 crank hp.
Ad a V3 and the kit will give you about 10 rwhp per pound of boost. With the stock pulley mine put out 10 psi. If you get a V3 buy a Anderson Power Pipe the stuff that comes with the kit sucks. Also upgrade to a 75mm T Body or bigger with a plenum to match. Ad some cams and a boost a pump to this and you'll be right around 400-410 rwhp. I'm running a Snow methanol kit I don't think I'd do it again the boost juice gets expensive and you go through it quicker than you'd think.
Old 06-22-2013, 10:08 PM   #24
Warbot's Avatar
Wont the cai be obsolete? Since when you get a blower it wont fit? And yeah ill probably do magnapacks or lm2 with o/r x and then go for the v3 and wait on the other stuff 360rwhp will be good and then if i want more it will just add faster. And whats the power pipe?
---------- Post added at 11:08 PM ---------- Previous post was at 11:07 PM ----------
Oh and the supplied injectors and maf and pump were those good enough or did you upgrade to what everyone else gets?
Old 06-23-2013, 06:37 AM   #25
Region: Vermont
The cai will be obsolete I just built my car in stages. The air inlet pipe that comes with the kit is cheap looking and undersized imo. http://www.andersonfordmotorsport.co...Induction.html
I still have the injectors that came with the kit but at around 360 rwhp your fuel system will be maxed out. I installed a Kenne Bell boost a pump to solve this problem.
Boost-A-Pump
Old 06-23-2013, 07:24 AM   #26
Rm360's Avatar
If you still have the stock fuel pump, the boost a pump and stock pump will max at 360 it's best to switch to a walboro 255lph or a Lincoln avaitior 285-315 LPH pump and use the boost a pump as a safety device just to insure you have enough fuel on the top end, stock fuel pump and boost a pump = crap!
Old 06-23-2013, 08:23 AM   #27
Warbot's Avatar
So basically instead of getting a new fuel pump you can get a boost a pump to get more flow?
---------- Post added at 09:23 AM ---------- Previous post was at 09:22 AM ----------
Oh okay just saw your comment about the pump hmmm just more and more expenses it seems haha....
Old 06-23-2013, 08:26 AM   #28
Rm360's Avatar
With a stock fuel pump and boost a pump set up you will be maxing the pump out at all times and it won't supply enough fuel on the top end , Kenne bell designed it to be used with a stock pump but it truly isn't efficent, your best bet is to upgrade the pump and use the boost a pump as a safety device it cost more but it's worth it in the end
Old 06-23-2013, 10:34 AM   #29
Warbot's Avatar
Oh okay gotcha, probably would be more cost effective to get the tuner kit maybe and buy injectors and fuel pump + boost a pump and maf then get a tune.
Old 06-23-2013, 11:52 AM   #30
BigB227's Avatar
+10000
I'd buy just the tuner kit and piece the fuel management system together yourself and all and have peace of mind
Old 06-23-2013, 02:43 PM   #31
Region: Vermont
I think the kit comes with the equivalent of a SVT Focus pump.
Old 06-23-2013, 03:14 PM   #32
2002VertGT's Avatar
Boost a pump should be used as a safety, not a fuel supply
03:04 AM
