Car wont start!! Help please!! - Mustang Evolution
Old 06-22-2013, 01:17 PM   #1
Corndog's Avatar
2001 gt with p1sc vortech. Car ran perfect I parked it and later that day got in it and it turns over fine and I'm getting fuel and spark. When it turns over sounds like it tries to crank but if I keep doing it then it will pop a lil thru the exhaust
Corndog is offline   Reply With Quote
Old 06-22-2013, 01:40 PM   #2
1996mustang's Avatar
Timing possible.....lets be truthful did you do hard driving earlier or just dd and it does this? If popping thru exhaust its a possible timing issue
Old 06-22-2013, 02:58 PM   #3
agree it sounds like timing
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-23-2013, 03:12 PM   #4
Corndog's Avatar
Even if it was driving and running perfect. Starting and cranking good. Then all of a sudden it don't want to crank and just turns over. When it's turning over you can hear it try to hit a lil to start but doesn't
---------- Post added at 03:12 PM ---------- Previous post was at 03:10 PM ----------
Before it started all this it did seem to hesitate in 3rd and 4th gear when I was trying to just build boost?
Old 06-23-2013, 04:19 PM   #5
What size injectors are u running? If u are backfiring a bit but it won't start i think u need to pull out a spark plug and disable the fuel pump to see if your flooding the engine. U have spark and fuel but maybe its flooding one or more cylinders and that would cause it to not start up
Is it manual or auto? If manual check to see clutch didnt get stuck with the tob could also cause a crank no start.....happened to an old fc rx7 of mine i flooded it cause tob cooked onto the clitch
Old 06-24-2013, 05:45 AM   #6
Mfore33's Avatar
Could be fuel pump went out. Mine ran fine till one day went to get food stopped engine then came out and no fuel pump
Old 06-24-2013, 06:01 AM   #7
+1 it could also be that
Old 06-24-2013, 10:41 AM   #8
Corndog's Avatar
I took the cap off my fuel rail and turned the switch on and it squirted out for like a second
Old 06-24-2013, 12:54 PM   #9
Mfore33's Avatar
Fuel pump could be weak. Just pushing small amount of fuel just enough to hear a sputter
Old 06-24-2013, 03:30 PM   #10
Corndog's Avatar
But my fuel pressure gauge in the car shows 41 when I turn the switch on
01:45 AM
