Steering problem help! - Mustang Evolution
Old 06-25-2013, 05:06 PM   #1
JayStang718's Avatar
I'm having a problem, everytime I turn the steering wheel left of right I hear a loud and annoying creaking sound coming from the front it evens happens when I'm braking to a complete stop it creaks in front. I just change my rack thinking that was the problem but that didnt do a dam thing. I'm thinking maybe I need to flush the system or change the pump itself.
JayStang718 is offline   Reply With Quote
Old 06-25-2013, 05:34 PM   #2
There are two metal sleeves that the mounting bolts for the steering rack go through. Do a Google search, I think there are replacement sleeves you can order to eliminate it
Old 06-25-2013, 09:37 PM   #3
1996mustang's Avatar
Control arm bushing or ball joint could also do a creaking sound....specially when u break cause the rack is bolted on and has nothing to do with supportingthe weight of a vehicle when u break.....just my 2ยข
07:10 AM
