Springs will be cut - Mustang Evolution
Old 06-25-2013, 08:39 PM   #1
Doe_Rae_mi's Avatar
Alright guys, im ganna cut my springs and install my camber plates, so should I cut my sportlines or my stock springs? I'm leaning more to cutting the stock springs incase I don't like the way it looks ican go back to my sportlines
Old 06-25-2013, 08:54 PM   #2
1slosix's Avatar
stock....NEVER cut progressive springs like the sport lines. your oem springs are linear so they are perfectly ok to cut. might i suggest 1.25 coils off the front and 1 coil off the back no isolators. always my favorite stance for a cut new edge
carving corners like a boss
Old 06-25-2013, 08:57 PM   #3
Doe_Rae_mi's Avatar
Yea sounds good. Right now I'm lowered Apperently 1.7 in front and 1.5 in back. Well my car is squatting so how much do I need to cut for 2 inches
Old 06-25-2013, 09:20 PM   #4
1slosix's Avatar
2 coils all four corners..you may wanna leave iso's in until after you see how it sits. if you want it lower pull them out for another 1/4"
Old 06-25-2013, 09:27 PM   #5
Doe_Rae_mi's Avatar
So every coil is an inch?
Old 06-25-2013, 09:36 PM   #6
1slosix's Avatar
surprisingly pretty much..however age of the springs also changes that because they can lose tension over time. you may do 1.5 coils off all 4 corners first to see. never hurts to be careful
Old 06-25-2013, 09:38 PM   #7
Doe_Rae_mi's Avatar
Hmmm alright thanks man!
01:03 AM
