A/C changing idle - Mustang Evolution
Old 06-26-2013, 04:26 PM   #1
04__gt's Avatar
A/C changing idle
When I have the car in park it idles at 1 and a quarter but when I turn the air on while its in park it idles down below one. Is this going to cause a problem or is this normal?
04__gt is offline   Reply With Quote
Old 06-26-2013, 07:22 PM   #2
very normal
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-26-2013, 07:34 PM   #3
AC is putting a load on the motor, therefore it'll run a little lower. Completely normal and will not hurt a thing.
Old 06-26-2013, 07:52 PM   #4
04__gt's Avatar
Thanks it's probably done it in every vehicle I've owned just noticed it this particular time
Old 06-26-2013, 08:04 PM   #5
Slp_loudmouth's Avatar
If it jumps up and down ( revs up for a few then a drop) you need freon
Slp_loudmouth is offline   Reply With Quote
Old 06-26-2013, 08:06 PM   #6
04__gt's Avatar
It's not doing any of that all it does is what I previously posted but ill be on the look out
Old 06-27-2013, 04:13 PM   #7
Mine idles at 600 with the a/c off. 800 when i turn it on??
Manual
Apex Predator is offline   Reply With Quote
Old 06-28-2013, 06:59 PM   #8
Mustang936's Avatar
Apex, that's totally normal. Idle is going to change with the a/c on due to load on the engine. Its more noticeable on manual cars at idle because the car is actually in neutral, rather than an auto where its still in gear but your foots on the brake.
Mustang936 is offline   Reply With Quote
01:02 PM
