Underdrive Pulleys - Mustang Evolution
Old 06-26-2013, 11:26 PM   #1
XSlashDashX's Avatar
Underdrive Pulleys
Is it worth getting? Was looking into the Steeda Pulleys on AM. How much mpg would I gain?
Old 06-27-2013, 12:03 AM   #2
3-5hp at the wheels... I had the BBK aluminums on my 5.0, they were very nice. I recommend not installing the alternator pulley. Its worth 1hp at most and the potential for charging issues makes it really not worth it.
2000 Mustang GT Steeda #0048
Old 06-27-2013, 12:07 AM   #3
What's wrong with the alt pulley?
Old 06-27-2013, 12:42 AM   #4
There can be issues with the alternator charging at low RPM. For what it's worth, Ford used uderdrive pulleys on the Bullitt. All of the accessories are underdriven but they left the crank pulley the original diameter.
Old 06-27-2013, 05:14 AM   #5
cliffyk's Avatar
I have the Steeda UDPs on my '03 GT, including the generator pulley, and have never had any charging problems. As to increase in fuel economy it will be minimal; 0.5 mpg at very best.
The most noticeable difference will manifest itself on hard acceleration in the lower gears, especially over 4000 rpm. If you are not the sort to do that you might want to reconsider spending time and money on UDPs...
Old 06-27-2013, 10:57 AM   #6
BigB227's Avatar
+1 this is one of those mods that if you dot spend quite a bit of time in the upper rpms you'll wonder if it was worth it. Like an aluminum driveshaft, only makes a big difference in high rpms for the rotational mass
BigB227 is offline   Reply With Quote
Old 06-30-2013, 06:37 PM   #7
Perricanfalcon's Avatar
I had the Steeda UDPs on my 03 GT and had charging issues which left me stranded twice and after the second time the next day switched back over to the stock pulleys.
Perricanfalcon is offline   Reply With Quote
Old 07-01-2013, 12:03 PM   #8
Nitrous02gt's Avatar
Do u have a system in your car?
Nitrous02gt is offline   Reply With Quote
Old 07-01-2013, 12:20 PM   #9
I had a "system" in my 95 Cobra. Kicker Amp, two 12s, aftermarket headunit and Pioneer speakers. Not so much a system as a decent stereo setup. I had 0 charging issues with the BBKs and the stock alt pulley. Even with the headlights on and the AC on at idle at night when the bass hit it was totally fine. No capacitor or anything. If there are charging issues that severe in a newer Mustang it might be the charging system is already weak and the pullies are just helping it along in its failure .
02:04 PM
