HELP white face glow gauges - Mustang Evolution
Old 06-27-2013, 12:37 PM   #1
Top stang's Avatar
So I got everything hooked up but when I turn on the lights they won't come on and be blue the only thing that lights up is the mileage and all my needles are way of the rev and speedo don't even move when I drive. Someone please help
Top stang is offline   Reply With Quote
Old 06-27-2013, 01:42 PM   #2
blackhawk 1's Avatar
I paid to have mine installed
blackhawk 1 is offline   Reply With Quote
Old 06-27-2013, 01:51 PM   #3
BigB227's Avatar
Sometimes when you install them you move the needles a bit too far down and they contact the gauges. I have to tap the plastic to unstick them and then they move no problem. And as for the wiring I believe you have to tap into the large brown wire or gray I can't remember.
BigB227 is offline   Reply With Quote
Old 06-27-2013, 02:05 PM   #4
Top stang's Avatar
Ok I took the needles off when I put my on could that be a problem
Old 06-27-2013, 02:15 PM   #5
9tee7pony's Avatar
When I did mine I ran the ground wire down to a screw on the fuse box under the dash.
9tee7pony is offline   Reply With Quote
Old 06-27-2013, 02:17 PM   #6
Top stang's Avatar
Do I had to have the black gauges under neath the white ones
---------- Post added at 01:17 PM ---------- Previous post was at 01:17 PM ----------
Do I had to have the black gauges under neath the white gauges
Old 06-27-2013, 02:34 PM   #7
What the hell is all this talk of wiring? Am I missing something? Every single time I've ever done new gauges/overlays all I do is pull the needles, lay the gauges on, put the needles back on and go. Obviously record where everything was first and get everything accurate. Put the needles back on with power to the cluster and make sure you take a picture beforehand so you know exactly where to go. Start the car for the tach and place it right where your sweet spot is at warmed up idle. For the speedo, I drive around with a GPS and the cluster cover off and play with it till I get it right.
edit: If these glow gauges do require some other source of lighting like if there is a wire coming off them for ground/power. Just tap into your ground/power... find a wiring diagram and splice away. Not rocket science.
2000 Mustang GT Steeda #0048
Old 06-27-2013, 04:13 PM   #8
Foxone's Avatar
The ones I got do not require you to remove the needles. But you do have to wire them if you want them to glow blue. Pretty sure you want to tap into the brown wire alos. Lastly, if they dont lay totally flat, the needles will rub, I glues mine down tight.
2015 GT Premium....
Foxone is offline   Reply With Quote
Old 06-27-2013, 04:49 PM   #9
351stroker's Avatar
Buddy bought his car with it installed, nothing lined up, speedo was way out basically it sucked so I ripped it out without him noticing. Lol. Back to normal.
---------- Post added at 03:49 PM ---------- Previous post was at 03:47 PM ----------
I hate to say but that's a ricer thing. Go with some tough looking gauges instead.
351stroker is offline   Reply With Quote
Old 06-27-2013, 06:54 PM   #10
BigB227's Avatar
You shouldn't have had to remove needles and that's probably why your having problems
Old 06-27-2013, 08:55 PM   #11
Agreed about the reverse glow rice.
Proper white faces below.
Old 06-28-2013, 07:21 AM   #12
Count Dragula's Avatar
I like the black gauges but reverse glow so you can only tell a difference at night
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
01:00 AM
