tie rod end replacement - Mustang Evolution
Old 06-29-2013, 07:44 PM   #1
v8pony's Avatar
looking into replacing my own tie rod ends, googled around for some how-to/tutorials but couldnt find too much, was hoping you guiys could lead me in the right direction on how to go about replacing these.
2002 5spd GT
Feb 2013 Mustang of the Month
Old 06-29-2013, 08:40 PM   #2
Tyoung68's Avatar
Its pretty easy to just gotta undo two nuts per side and measure how far it sticks out so your alignment can be close
Old 06-29-2013, 10:07 PM   #3
Slow4V's Avatar
Take off the wheel
Try to mark how deep the tie rod screws on the rack ..
Get some needle nose pliers and take out the pin on the tie rod crown nut
Get a 15mm and remove the crown nut
Now put the crown nut on the threads but only spin it a couple times..
Get a good size hammer and hit the **** out of the tie rod on its side til it drops down .. Then unscrew the nut and just tap the tie rod down .. And unscrew it off.
You need a alignment after your done
Old 06-29-2013, 10:15 PM   #4
v8pony's Avatar
Originally Posted by Slow4V View Post
Take off the wheel
sounds pretty simple, thanks man
2002 5spd GT
01:41 AM
