3.8 to 4.6 swap - Mustang Evolution
Old 06-30-2013, 09:42 AM   #1
Stang_lover00's Avatar
3.8 to 4.6 swap
Eventually I want to swap my 3.8 to a 4.6. Does anybody know what exactly I would need to have in order for me to swap a 4.6 in?
Stang_lover00 is offline   Reply With Quote
Old 06-30-2013, 12:26 PM   #2
Region: Arkansas
Go ask in the v6 section. They're the ones that will have done the swap and have better information.
Off the too of my head:
Motor
ECU
new harnesses
ABS module
TC module
New motor mounts
Probably new K member depending on what you have right now. I don't know what the v6 came with.
Much more that I can't think of
BackPressure is offline   Reply With Quote
Old 06-30-2013, 12:31 PM   #3
austinknoll's Avatar
You need a lot of stuff. Go search it on google. Other forums have compete write ups and parts lists for the swap.
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 06-30-2013, 12:37 PM   #4
32vNomad's Avatar
You will need a GT harness, ECM/CCRM as well as harness to ECM. 4.6L, if your going 5 spd that will be the easiest. The read end should be upped to an 8.8. are you looking 2v or 4v
K member is the same, new gt mounts, also you will need the hydroboost brake system as the power air booster will not work with the 4.6L
v6 to 4.6 dohc photos
32vNomad is offline   Reply With Quote
Old 06-30-2013, 12:49 PM   #5
White03GT's Avatar
+1! Me and my brother are getting ready to do a 5.0 swap in a 95 v6 that he blew
White03GT is offline   Reply With Quote
Old 06-30-2013, 01:06 PM   #6
Damn, um probably 2v
Old 06-30-2013, 04:53 PM   #7
32vNomad's Avatar
There would be an easier goal. There are a lot of things to that swap. But if you were to find a crashed gt it maybe the best. I know places like LKQ sell motors for 250 if you pull. But tracking everything down can get pricey. Maybe a pushrod 5.0 might work for less. There was the 99 saleen S351 it was the only 351 produced in a new edge body. With that swap you could find a 95 k member. That way the brake booster can be left alone. I would look into that if I had a V6.
Old 07-02-2013, 06:12 PM   #8
evergne's Avatar
I have a 98 gt engine and the pcu I can sell to you. All the engine has is a spark plug hole is stripped. Good to do a pi head swap.
evergne is offline   Reply With Quote
Old 07-03-2013, 11:02 AM   #9
If you're going to put all that work into swapping a motor, why not go for something with more power?
65 Mustang coupe
Old 07-03-2013, 11:11 AM   #10
evergne's Avatar
What he says is true but will be a lot more expensive. Im in the process of doing the swap for a coyote and is **** expensive. That is why I have the 2v and pcu available with stock kmember and steeda springs if anyone is interested.
Old 07-31-2013, 07:10 AM   #11
R03GT's Avatar
No real point in swapping in a 2v 4.6 might as well just buy a GT at that point you can find them for 6-8k which I can assume equals or is slightly less costly then a swap depending if you do the work yourself or not.
R03GT is offline   Reply With Quote
Old 07-31-2013, 07:49 AM   #12
Slow4V's Avatar
Not worth it
Old 07-31-2013, 09:06 AM   #13
Originally Posted by Slow4V View Post
Not worth it
Which is why im not doing it, im saving for a 03-04 cobra
11:50 PM
