1998 mustang gt automatic shifter LINKAGE - Mustang Evolution
Old 06-30-2013, 05:58 PM   #1
calebnaasko's Avatar
Just bought a 98 gt and the dealer said it needs a shifter linkage. It's an auto and its hard to shift it into drive. It runs smooth and has no trans issues
calebnaasko is offline   Reply With Quote
Old 07-01-2013, 01:24 AM   #2
98GTCONV's Avatar
Sounds like you just need to adjust the cable.
98GTCONV is offline   Reply With Quote
Old 07-01-2013, 01:34 AM   #3
Where is it located?
Old 07-01-2013, 01:40 AM   #4
98GTCONV's Avatar
Side of trans, if you can, get it on jack stands, have someone go through whatever gears are giving you problems and adjust the cable until it shifts smooth. I did this with mine when it didn't know it was in park and wouldn't crank
Old 07-01-2013, 01:49 AM   #5
The dealer I bought the car from said it needed a "new" shifter cable linkage. They run about $100 used. What side of the trans?
Old 07-01-2013, 01:50 AM   #6
98GTCONV's Avatar
I would check to see if its loose first. I think its drivers side
Old 07-01-2013, 01:55 AM   #7
Also it is hard to get it into every gear, I have to put it in "2" for "D" Drive=Neutral and 2=Drive
Old 07-01-2013, 08:38 AM   #8
BigB227's Avatar
Buy a Haynes manual and you can do this yourself man lol I did it on my 2003 automatic in I time
BigB227 is offline   Reply With Quote
Old 07-01-2013, 09:15 AM   #9
It should be on the drivers side in between the tranny and mid pipe. You cannot miss it.
UDBigJim is offline   Reply With Quote
04:23 PM
