Blowing fuses - Mustang Evolution
Old 07-01-2013, 12:32 AM   #1
d_1212's Avatar
Blowing fuses
I recently purchased new raxiom taillights for my car w the led reverse bulbs and everything seemed to go well and was working properly and the next time I started the car my brake lights, turn signals or fog lights wont work but My reverse lights still work n headlights r fine. I checked the fuse for the brake lights and it was blown. Is it just an easy fix n should I just swap the fuse or is something wrong here n will I just keep blowing the fuses??? Help!!!
d_1212 is offline   Reply With Quote
Old 07-01-2013, 01:04 AM   #2
Try another fuse. Make sure that it is the correct amperage for the position in the fuse box. If that one blows as well, yes, there is something wrong and you will have some electrical troubleshooting to do my friend...
Old 07-01-2013, 10:25 AM   #3
d_1212's Avatar
I didn't rewire anything tho just plug in two new LEDs for reverse lights popped on new housing and that was it
Old 07-01-2013, 10:36 AM   #4
Just double check everything that you did and try it again...
04:26 PM
