Strange tranny / drivetrain noises - Mustang Evolution
Old 07-02-2013, 02:02 AM   #1
Arron's racecar's Avatar
Region: Nevada
Hey guys, I've tried the search function to no avail. And I just want to know what is broke. When driving (in any gear) I hear a strange rattle/chatter noise from what sounds like the tranny. But I believe it's not the motor because when it's in neutral and/or the clutch pedal is depressed I can rev it up to redline and there is no noise so it only does it while in gear and under load. I don't know what to do but it's driving me crazy. Any help or advice would be appreciated!
2004 GT current mods : CAI, BBK Short throw shifter TB and UDPs, SCT x3/SF3 with BAMA Perfomance tunes Roush body kit, roush side skirt exhaust and paint.
Arron's racecar is offline   Reply With Quote
Old 07-02-2013, 07:15 AM   #2
Region: Arkansas
Probably clutch chatter since it only occurs under load.
Have you recently replaced the clutch/flywheel?
BackPressure is offline   Reply With Quote
Old 07-02-2013, 12:12 PM   #3
Region: Nevada
It's a ram clutch with less than 5000 miles on it and the flywheel is stock just had it resurfaced when I had the clutch swap done. What would be causing the chatter?
Old 07-02-2013, 02:11 PM   #4
Region: Arkansas
There's your problem. RAM clutches are cheap for a reason. Google will autocomplete RAM HDX clutch with "chatter". They're that bad.
I'm not saying all RAM clutches are crap because that's unfounded and unnecessary, but it's a common problem.
That's why OEM (Valeo in this case) is always the best bet.
Old 07-02-2013, 04:13 PM   #5
Region: Nevada
Well then it would seem that I wasted a bit of money cuz I'm not even happy with how it performs either ok well if I'm going to do another clutch I'm thinking about going with the exedy stage 2 w/flywheel. has anyone tried these they have good reviews but I don't want to waste more money but I'm looking for a bit more bite than oem.
Old 07-02-2013, 04:26 PM   #6
Region: Arkansas
You don't need anything more than an OEM cobra clutch. That's what I have and it will hold more power than I could ever make. Plus, it's cheap and grabs like a bear trap.
Exedy is amazing if you want to get one though.
Old 07-02-2013, 04:30 PM   #7
Region: Nevada
Ok sounds good thank you. I really appreciate the help!
Old 07-02-2013, 04:33 PM   #8
Region: Arkansas
Sorry to hear you didn't like the clutch.
Old 07-02-2013, 04:34 PM   #9
Region: Nevada
It's ok, shoulda just sprung for the good stuff in the first place xD. Oh well lesson learned
Old 07-02-2013, 04:35 PM   #10
Region: Arkansas
Fidanza makes excellent aluminum (which you definitely want) flywheels for the record. Centerforce's Dual Friction clutch is also great!
Old 07-02-2013, 05:13 PM   #11
Region: Nevada
Yeah the exedy is an aluminum flywheel too so I'll probably just get the set
Old 07-02-2013, 06:46 PM   #12
I have the exedy stage 2 and the exedy billet steel flywheel. A little chatter in the 1-2 shift, but nothing to bad. Grabs hard and pedal feel not to much of from stock. I like it.
Old 07-02-2013, 07:03 PM   #13
Region: Nevada
Sweet I would be getting the lightweight aluminum fly wheel and the stage 2 from AM. I'm glad to hear they make a good product though!
10:35 AM
