Tune-up cost? - Mustang Evolution
Old 07-04-2013, 01:42 PM   #1
to_oaxaca's Avatar
Region: Nevada
Tune-up cost?
Can someone tell me the average tune up cost for a 00 Mustang Gt, in LV? (this would include spark plugs, cables, oil, oil filter, and air filter)
to_oaxaca is offline   Reply With Quote
Old 07-04-2013, 01:53 PM   #2
assuming its a 4.6 liter I work at a rinky dink parts store & selling you motorcraft plugs, air filter, oil filter, & oil & some prestolite brand wires would run ya about 122$ at my store
Old 07-05-2013, 11:45 AM   #3
1lowGT's Avatar
Depends on how cheap you go. Plugs get motor craft. Oil I done royal purple oil and oil filter most won't go that extra $$ but I did. You can find cheaper and good oil. Are you changing all this yourself??
Old 07-05-2013, 10:05 PM   #4
To DIY?
-6 qts of 5w-20 oil and FL-820S filter at Wal-Mart is $21
-Autolite spark plugs are $3/plug
-3 qts of Mercon V for the trans (manual) is $4-$5/qt (much more for auto)
-Air filter... I honestly have not bought a paper filter for a stang in forever, figure $20?
-Cables... I'm assuming you mean spark plug wires... you don't have any. You have what is called a "COP" (coil over plug) and this is where it gets expensive. $45ish PER COP for the Motorcraft ones which are the ONLY ones you should ever buy. You don't necessarily need them though but if the miles are very high its only a matter of time before they start failing one by one.
You should also do the rear end fluid while you are at it, 75w-140 is what goes in the rear and its very pricey at $20 per bottle IIRC but if its the stock fluid from 00 its very likely laquer by now and should be drained/filled and don't forget the friction modifier.
Old 07-08-2013, 08:52 AM   #5
JayStang718's Avatar
Honestly that's all relatively easy stuff there are tons of how to videos on how to do tune ups (plugs, oil change, fuel filter, air filter, etc)
JayStang718 is offline   Reply With Quote
10:26 PM
