wide rears - Mustang Evolution
Old 07-06-2013, 11:31 PM   #1
stanglover85's Avatar
wide rears
What are some decent wide rears that I can put on my car? I don't like the looks of my 245/45/17s from behind
stanglover85 is offline   Reply With Quote
Old 07-06-2013, 11:39 PM   #2
Venomouz831's Avatar
305's or 315's
)02 Gt, Founder of WE2G
Old 07-06-2013, 11:42 PM   #3
And would I have to buy new rims to put those tires on or would they actually fit
Old 07-06-2013, 11:47 PM   #4
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
The widest your stock wheels will take is about a 275 width tire.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 07-06-2013, 11:49 PM   #5
I figured as much... That's ok ill have to save up cos I want and need the wide rears... Cars been modded and wants to slip and slide everywhere
Old 07-06-2013, 11:49 PM   #6
Doe_Rae_mi's Avatar
If you go 315 u need a 10.5 rim
Old 07-07-2013, 12:01 AM   #7
Don't technically need it. You can have a 10' and it will fit.
Old 07-07-2013, 12:02 AM   #8
10. 10.5 price dif can't b much wonder what the weight diff between the 2 are
Old 07-07-2013, 12:10 AM   #9
No more than 3-5lbs. I ran a 315 on my 10' rim before
Old 07-07-2013, 08:21 PM   #10
Region: Arkansas
+1
Not much of a weight difference.
It is worth noting that Nitto 315s are NOT really 315. Nitto is notorious for running narrower that they claim. That said, I went ahead and purchased a 10.5" wheel just to be safe for my 315s.
BackPressure is offline   Reply With Quote
Old 07-07-2013, 11:42 PM   #11
Nitto 555R on a 10.5" wide rear wheel.
With the Nittos, I usually subtract 20 from the tire width number. For example a 315/35/17 Nitto would be like a 295/35/17 in another tire.
Old 07-07-2013, 11:45 PM   #12
1slosix's Avatar
lol that's for sure...my 275/40/17 555R's were taller and skinner then my 275/40/17 Nexen 3000's
carving corners like a boss
Old 07-08-2013, 01:23 AM   #13
Slow4V's Avatar
You can put 315 on 17x9
Old 07-08-2013, 04:38 AM   #14
EricJames's Avatar
I would deff NOT put 315 on a 9 inch wide rim
EricJames is offline   Reply With Quote
Old 07-08-2013, 07:50 AM   #15
White03GT's Avatar
+1!
White03GT is offline   Reply With Quote
Old 07-08-2013, 09:58 AM   #16
Slow4V's Avatar
No balls lol
I ran 315s on a 9 for 2 years no problem
Old 07-08-2013, 01:05 PM   #17
A Nitto 555R 315 would got a 9" rim no problem... Again, they run narrow.
Old 07-08-2013, 01:39 PM   #18
Mile high JDF's Avatar
Double post
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-08-2013, 02:05 PM   #19
I put some 315 Nitto's on 17X9 Cobras for my buddy but it bulged out way too far. He's just fine with it but I wouldn't recommend it and most shops won't mount them for you.
Old 07-08-2013, 04:25 PM   #20
Nitto 315s on 9" wide rims look like 275s on the stock rims IMO. Not ideal but they'll fit and it won't be dangerous. It won't hook up as good as a properly fitted tire though, wider is not necessarily better.
Old 07-08-2013, 04:34 PM   #21
Slow4V's Avatar
Yeah they had horrible traction, but I just wanted the look
Old 07-08-2013, 05:42 PM   #22
My 555Rs hook up great
Old 07-08-2013, 08:21 PM   #23
Region: Arkansas
+1
Slow just had a shtty setup.
Old 08-19-2013, 06:16 AM   #24
Yea I need the extra tire to help hook up but also want the look
Old 08-19-2013, 07:31 AM   #25
1996mustang's Avatar
335/35/17 ftw lol im trying to get a set of those for mine. Viper tires look good
Old 08-19-2013, 08:30 AM   #26
325/40/17 Mickey Thompsons would do the trick too...
Old 08-19-2013, 09:31 AM   #27
1lowGT's Avatar
335/35/17 Hoosiers
Old 08-19-2013, 01:20 PM   #28
Need more sidewall than a 35 if you are going to to some serious strip racing. Even 40 is not really enough... There's a reason ppl put 15" weld rims on their cars and run thickass sidewalls aired down to 8 psi in the tire.
Old 08-19-2013, 01:24 PM   #29
Get some of these, best hooking tire I've used so far
Old 08-19-2013, 01:31 PM   #30
Attachment 124664
Booooooiiiiinnnggggg....
Old 08-19-2013, 01:35 PM   #31
2300turboford's Avatar
+1
Old 08-19-2013, 01:42 PM   #32
03fastblack's Avatar
Where did you get those tires?
03fastblack is offline   Reply With Quote
Old 08-19-2013, 01:42 PM   #33
Here's my tire pr0n from the back.
Old 08-19-2013, 01:45 PM   #34
A local vendor. Haven't been in touch with him, will need to soon since I need new rears
Old 08-19-2013, 01:48 PM   #35
What size are they?
04:26 AM
