No luck at all! Help me!! - Mustang Evolution
Old 07-08-2013, 08:27 PM   #1
Jord05's Avatar
So after a week of putting new plugs in my car they are once again wet and fouled its every plug on the driver side barely idles now and back fires a bunch help me I just want to drive my car into a lake already grrrrr!!!!!!! Time to sell it dirt cheap if its a huge problem
ID:	117348   Click image for larger version
Jord05 is offline   Reply With Quote
Old 07-08-2013, 08:31 PM   #2
1996mustang's Avatar
What is it soaked in oil or coolant? It could be the intake manifold or worst case head gasket on the driver side. But first things first what is it soaked in?
Old 07-08-2013, 08:32 PM   #3
Jord05's Avatar
Coolant
Old 07-08-2013, 08:37 PM   #4
Sounds like the intake manifold is leaking from that side. I would check the seals from the coolant crossover where the thermostat sits they can leak from there right into the valley to the plugs. I would say try to find a trail of coolant. Normally white looking residue would help start a search for a leak. If anything else run the car while with a flashlight look only on the driver side for Any leaks as well as the smell of coolant will help pinpoint the source of the problem
Old 07-08-2013, 08:39 PM   #5
Jord05's Avatar
Nothing at all and it's a new motor!
Old 07-08-2013, 08:43 PM   #6
The motor is toast... I'll give you $500 for it.
Old 07-08-2013, 08:44 PM   #7
If its a new motor there wouldnt be any leaks. Im just trying to help by pointing u in the direction to find a leak. It has to be leaking from either the manifold or the crossover or which i completelyforgot to mention the heater hose that runs under the manifold directly by the driver side which would also spray coolant onto the plugs
---------- Post added at 10:44 PM ---------- Previous post was at 10:43 PM ----------
Take a flashlight and look under the manifold for coolant
Old 07-08-2013, 08:45 PM   #8
Jord05's Avatar
No it is a new motor that's the part that makes me mad ! And I can't find the leak
Old 07-08-2013, 08:48 PM   #9
Have u looked where i stated to look? Those are the likeliest places to leak onto the plugs
---------- Post added at 10:48 PM ---------- Previous post was at 10:47 PM ----------
And by new u mean as in dealership or crate engine new or was it a new used motor
Old 07-08-2013, 08:49 PM   #10
Either the intake manifold is broken or the gasket is leaking.
Old 07-08-2013, 09:34 PM   #11
I can see the plastic coolant crossover plain as day. Your new motor has a non-updated PI intake that is a known issue. Also just because it is new doesn't mean it won't leak or can't leak. I'd yank that intake and put an updated one on with the metal crossover and go from there.
Old 07-08-2013, 10:48 PM   #12
Xtrosity's Avatar
If it is every plug on the drives side, it sounds like an intake problem way more than a head gasket problem.
Xtrosity is offline   Reply With Quote
05:02 AM
