Drag strip issues. - Mustang Evolution
Old 07-09-2013, 03:52 PM   #1
Region: Hawaii
Drag strip issues.
I recently took my 04 GT to the local drag strip for the first time. It has a flowmaster exhaust and JLT CAI. This was my first time in this car but I have raced numerous other mustangs. I am running stock rims and tires with the stock gears. I could only manage a 15.1 @96MPH. My 60ft's were at best 2.59. I tried every method I could think of to get the car out of the hole but it would not hook up at all. I am thinking of throwing some upper and lower control arms on over this weekend. Other than drag radials does anyone have any good advice? thanks guys.
Pat12p is offline   Reply With Quote
Old 07-09-2013, 04:44 PM   #2
Try slipping the clutch from around 3-3.5k. That will be your best bet along with dropping your tire pressure a little.
Apex Predator is offline   Reply With Quote
Old 07-09-2013, 09:04 PM   #3
Gears gears gears gears gears gears gears.
Old 07-09-2013, 09:09 PM   #4
1shotkllz's Avatar
X7
1shotkllz is offline   Reply With Quote
Old 07-10-2013, 12:25 PM   #5
Region: Hawaii
I appreciate the help guys. I've got some 4.10's on there way and a set of control arms. I'll try slipping the clutch again, it's probably has alot to do with my technique and stock rear end. Thanks for the help!
Old 07-10-2013, 12:40 PM   #6
1shotkllz's Avatar
You'll notice a big difference with those 4.10s.
Old 07-10-2013, 01:24 PM   #7
jjsg09's Avatar
Hooking up at the line is where you need to concentrate on. Gears would just make you spin more until u get some good rubber. Some radials or Hoosier slicks would change that 15 sec 1/4. When I bought my 02 GT i took it to the track the first week and got a14.3 first pass a month later I put a set of Nitto radials on and dropped it down to a 13.9 that's with only the tires and a cai done to it. It also depends on the driver and experience.
Old 07-12-2013, 08:04 PM   #8
Region: Hawaii
14.94 today with a 2.45 60ft. It's definitely a tire issues.
Old 07-12-2013, 08:36 PM   #9
Nothing like sticky tires out back to help you hook up. I LOVE my nice wide Nitto 555Rs. Also having a good set of control arms out back helps.
Old 07-13-2013, 01:04 PM   #10
My best is a 14.3 with a 2.3 (or 2.4, I forgot) 60 foot. If I can get it to 2.0 I should be at mid 13s
Old 07-13-2013, 02:23 PM   #11
Ewokjax95's Avatar
Pretty crazy what gears and a tire will do at the track. With 4.10s and a bias ply ET street, i pulled a 1.8 60'... on the same pass I blew up the clutch.
Ewokjax95 is offline   Reply With Quote
04:21 PM
