Fuel/boost for desired hp - Mustang Evolution
Old 07-10-2013, 12:09 AM   #1
Tomb1987's Avatar
Ok quick rundown. My motor should be finished at the builder within a week or 2 waiting on valves.
Mach1 block
5.0 stroker
Forged rotating assembly
Race ported heads
Comp stage2 cam
Full bolt ons
Intercooler blow through maf. Power pipe
Vortech v3 roughly 8lbs of boost
The question is I have 39lb injectors walboro single 255 pump. How much power can this setup hold reliably
If I upgrade I'm going to 03 cobra twin pump 60lb injectors, how much power will this hold.
My goal is 550-600 whp what do I need fuel wise and with my motor how much boost will I need to get their.
2002 mustang gt
Future beast
Tomb1987 is offline   Reply With Quote
Old 07-10-2013, 07:43 AM   #2
onesickstang01's Avatar
With that fuel system you will run out of fuel probably before you break 400 whp. You will need twin super car pumps and 60s to hit that 600 ish mark. And you will have to run around 15 psi to hit that kind of power with the v3. Basically same setup I'm running making 602whp
onesickstang01 is offline   Reply With Quote
Old 07-10-2013, 04:11 PM   #3
Tomb1987's Avatar
So cobra tank
Twin gt pumps
60lb injectors
15 lbs boost should get me their
2002 mustang gt
Future beast
Old 07-10-2013, 04:54 PM   #4
NewMtang's Avatar
Is that an H&K P2000?
Old 07-10-2013, 07:39 PM   #5
Tomb1987's Avatar
Sig sauer sp2022 .40
I hate that gun lol my Springfield is better
2002 mustang gt
Future beast
12:05 PM
