Let's talk Coil on Plugs - Mustang Evolution
Old 07-10-2013, 12:23 PM   #1
Well one my Coils crapped out P0358. I was just going to replace that one for the time being with a n oem motorcraft. As some of you know the oems are pretty expensive. Has anyone else tried a different brand with success?
I looked at the Accel coils and they are just under 200 for all 8.
Heck there are some as low as 14 bucks for a single one on amazon with great reviews.
So what are you using currently or what are you planning on getting for replacements?
Apex Predator is offline   Reply With Quote
Old 07-10-2013, 02:26 PM   #2
1lowGT's Avatar
I had to replace one. Just went went oem
Old 07-10-2013, 03:18 PM   #3
2000 Mustang Gt's Avatar
I replaced all 8 of mine with the motorcraft coils. I got them for 352.00 on rockauto.com That was the best price I could find on motorcraft.
2000 Mustang Gt is offline   Reply With Quote
Old 07-10-2013, 03:45 PM   #4
I went and ordered all of them once and for all
Old 07-10-2013, 06:12 PM   #5
That's the way to do it. I just got home and on my porch were two giant boxes from Rockauto with my new Motorcraft coils and a whole bunch of other goodies. I'm so happy. It's like Christmas. Only I had to pay for it all.
Old 07-10-2013, 07:04 PM   #6
Iggy's Avatar
Hi guys hey I wondering when a coil is bad how does the car act? I am having a problem when I wash my car or it gets damp it like bogs down and loses power then as soon as it warms up its fine. Does that sound like coil problem ?
Iggy is offline   Reply With Quote
Old 07-10-2013, 07:27 PM   #7
Usually, a bad coil will cause a misfire at idle (like mine is doing) and escalate from there to a complete failure, I suppose. Not sure about your moisture problem. Maybe open the hood when you're finished washing and try to find out if anything is getting wet.
Old 07-10-2013, 07:37 PM   #8
White03GT's Avatar
More then likely a coil. I say next time it happens scan it and find out. Autozone does it for free if you don't have anything to pull a code with
White03GT is offline   Reply With Quote
Old 07-10-2013, 08:30 PM   #9
Hopefully OEM and hopefully from Rockauto and hopefully the correct ones for the 2V. DG508 is the 2V motorcraft part number.
Old 07-10-2013, 11:08 PM   #10
FordAddict's Avatar
Any aftermarket ones will work
FordAddict is offline   Reply With Quote
Old 07-11-2013, 03:36 AM   #11
Count Dragula's Avatar
Yeah and miss fire bad again
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-11-2013, 05:56 AM   #12
They'll work... and then crap out after 20k...
Old 07-11-2013, 10:22 AM   #13
FordAddict's Avatar
Ive used many aftermarket ones. Just don't buy the cheapest quality ones out there. The accel ones aren't that good. You can actually take them apart and see they aren't quality.
Old 07-11-2013, 10:26 AM   #14
Lorraine's driver
ab_mach1's Avatar
Even the Accel ones die way before the OEM COP's. OEM is well worth the money.
Instagram: @ab_mach1
Old 07-11-2013, 10:30 AM   #15
FordAddict's Avatar
MSD is my choice there
Old 07-11-2013, 10:45 AM   #16
Lorraine's driver
ab_mach1's Avatar
You'd think MSD and Accel would have it down pat given their history, but I wouldn't buy their COP's if I'm paying with my money. Different story if its not COP's.
Old 07-11-2013, 11:24 AM   #17
MSD is junk. Ever see the inside of one of their ignition boxes? Looks like it was assembled by a 6 yr old with a hot glue gun.
Probably was somewhere in China...
Old 07-11-2013, 02:06 PM   #18
Yeah I got the DG508 motorcraft. I hope it fixes various problems that i am having regarding the misfire. I also need to check the a/c
Old 07-11-2013, 02:12 PM   #19
Lorraine's driver
ab_mach1's Avatar
I use a little dielectric grease in my boots so it gets a good connection to the plug.
Old 07-11-2013, 05:37 PM   #20
This is good practice whenever you do the plugs regardless whether its a COP or a wire boot.
12:01 AM
