Mustang mach 460 radio help:( - Mustang Evolution
Old 07-10-2013, 02:25 PM   #1
calebnaasko's Avatar
So I got a premium Lincoln radio from the junkyard and it works but I get no sound. I have a 98 gt and the plug for the speakers doesn't fit on the radio. I've had many other stangs with mach 460 and never seen this plug
calebnaasko is offline   Reply With Quote
Old 07-11-2013, 06:18 PM   #2
Geiger's Avatar
Try getting the plug from the lincoln at the junk yard and splice it with a harness adaptor from walmart or best buy and try that. This would be alot easier with a wiring diagram for the lincoln so you knew which wire is which . Just make sure you leave slack in the junk yard plug so you have something to work with. That should make it plug and play for about $10
2008 GT/CS , 17k original miles, bagged with airlift v2, cammed, and some bolt ons.
Geiger is offline   Reply With Quote
Old 07-11-2013, 08:47 PM   #3
But the original ford mach 460 has the same radio plugs. So I'm confused
Old 07-12-2013, 04:18 AM   #4
Geiger's Avatar
I thought you said the plug for the lincoln is different than the ford?
Old 07-12-2013, 12:50 PM   #5
No the Lincoln radio I purchased has the same plugs as a ford radio. Because I had a 96 mustang and took the radio out and it's the same as this Lincoln I just bought. I'm confused because in my car, the speaker plug has no where to plug into
02:35 PM
