Can somebody please help!! - Mustang Evolution
Old 07-10-2013, 03:22 PM   #1
JayStang718's Avatar
Can anybody please tell me what this sound is its driving me crazy. I replaced the rack, flushed my power steering, and just replaced the brackets that the rack sits on (they look like silver tubes) and its still making this dam noise.
---------- Post added at 05:22 PM ---------- Previous post was at 05:22 PM ----------
Btw it's a 04 gt
JayStang718 is offline   Reply With Quote
Old 07-10-2013, 10:06 PM   #2
1996mustang's Avatar
It sounds like your ball joints and maybe control arm busgings. However ball joints seem to be the culprit on the creaking noise. Have u tried to see if it makes noise while the front tires are elevated? It could atleast rule out a couple of things like the p/s pump which it sounds like a bit while the car was creeking
Old 07-10-2013, 10:37 PM   #3
The sound happens when the car is on the ground. I had it on a lift and when I turn the steering wheel I hear nothing. I don't think it's the pump tho this creak is different. And from what I recall the control arm bushing looked fine.
Old 07-10-2013, 10:42 PM   #4
Region: Nevada
It's probably your own farts
Adrian is offline   Reply With Quote
Old 07-10-2013, 10:59 PM   #5
v8pony's Avatar
Lmao +1...stop farting jay, that should help!
2002 5spd GT
Feb 2013 Mustang of the Month
Old 07-10-2013, 11:01 PM   #6
I can't help It I have a problem
Old 07-11-2013, 06:15 AM   #7
jjsg09's Avatar
Its one of your ball joints. Fords are notorious for ball joint failures. The reason you dont hear it when you lift the wheels off the ground is because there isn't any weight on the faulty ball joint. I would honestly buy all four for the front and change them all before they slowly fail one by one. You can rent the tool to remove/install them from any parts store.
Old 07-11-2013, 01:17 PM   #8
Yeah it was a bad ball joint the other wasnt as bad as this one but thanks for your help guys
Old 07-11-2013, 01:23 PM   #9
glad you found the problem and resolved it
10:45 AM
