cheapest tuner with most features? - Mustang Evolution
Old 07-10-2013, 05:19 PM   #1
Harper's Avatar
who makes the best/cheapest hand help tuner that has most of the features you need to a basic tune for performance, etc.
2003 COBRA/2004 GT w DOHC Cobra Engine and trans/5spd. IN PROGRESS
67 Mustang Coupe.
1965 F100 w/EFI 5.0 w 5spd.
Harper is offline   Reply With Quote
Old 07-10-2013, 05:30 PM   #2
TheStefanOrand's Avatar
I have the Diablo tuner and it has so much features:
-Two pre-set tunes for different fuel octane
- Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
-Timing table (+10% / -40%)
-Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
-Fuel table (+40% / -15%)Idle (+/- 20%)
-On/Off switch for Traction Control
-Raise Speed Limiter and Rev Limiter
-Re-Calibrate Speedometer for Gear and Tire Size Change
-WOT Shift Pressure
-Part throttle shift firmness
-RPM Shift Points
-Torque Modulation (for better shift feel)
-Cooling Fan ON/OFF Temperatures
All for about $350
---------- Post added at 05:30 PM ---------- Previous post was at 05:29 PM ----------
Also, it reads check engine lights
TheStefanOrand is offline   Reply With Quote
Old 07-12-2013, 08:47 PM   #3
Harper's Avatar
thanks for the reply, that's a lot of parameters that can be changed. how many different models will it service or do you have to have several for different cars, ie I am guessing a 03 cobra vs a 04 GT would be a different model as well as a 99 V6?
67 Mustang Coupe.
Old 07-12-2013, 08:50 PM   #4
I just bought a Moates QH for $125 barley used but that's not a handheld. They're $250 new. Another $40-$65 for software and you can tune any parameter you want and datalog. I am actually a tuning noob even after owning multiple mustangs for all these years so I'll be learning on this thing.
Old 07-13-2013, 06:35 AM   #5
cliffyk's Avatar
Delta Force Tuning's Special Forces package has the richest set of options (read more about it here) and can tune two cars as delivered, with no limit as to how many times you can change vehicles (many others have a 5 vehicle change limitation).
Additional licenses ("bullets") to tune more vehicles can be purchased, and you can upgrtade to their Commando professional level system...
09:07 AM
