common vac leaks? - Mustang Evolution
Old 07-11-2013, 05:32 PM   #1
Count Dragula's Avatar
common vac leaks?
I still have a vacume leak after I replaced my iac so what could it be?
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-11-2013, 09:03 PM   #2
jjsg09's Avatar
On the back of your plenum there is a vacuum hose check and make sure it's still plugged in. Also check out its condition. What is your car doing?
Old 07-12-2013, 02:59 AM   #3
At idle there is a minor difference but I csn hear it. Like a small cam kinda like it gurgles. Then under slight acceleration it studders a little but under heavy acceleration it is fine. I did check that hose and it is crusty feeling
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-12-2013, 03:52 AM   #4
Would that explain the loud intake noise at times?
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-12-2013, 07:39 AM   #5
jjsg09's Avatar
No but that sounds like you have the infamous cracked intake leak. The intakes are plastic and they can crack and cause some weird intake problems.
Old 07-12-2013, 07:45 AM   #6
I just put a new intake on. So I know its not that because its done it before and after. It just makes a slight sucking sound when im just cruising or slowing down. I felt back there last night and that hose was crusty and brittle so im thinking thats where the vac leak is. How much does it cost to get fixed?
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-12-2013, 07:47 AM   #7
jjsg09's Avatar
Ok well just take that hose off and take it to a parts store for matching measurement. They have rolls of vacuum lines. Yea that's a forgotten vacuum line it hidden.
Old 07-12-2013, 07:49 AM   #8
Do you know where it goes off of the plenum?
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-12-2013, 08:43 AM   #9
jjsg09's Avatar
I cant remember
» Members Mustangs
Katy
Gio_5.0
2007 GT
E_Sam
Add your Mustang
06:50 PM
