What did I break? - Mustang Evolution
Old 07-12-2013, 06:52 AM   #1
Kevo91's Avatar
Region: Utah
What did I break?
Hey all. So im cruising to work in my 98 gt and I casually turned left through an intersection in 2nd gear and boom! My car made a very loud clank/pop sound in the front end somewhere. I checked my tires good when I got to work but they were fine, I thought maybe I broke a ball joint but the car drove just fine the rest of the way to work...any thoughts on what it is or what I should check?
Kevo91 is offline   Reply With Quote
Old 07-12-2013, 08:51 AM   #2
1lowGT's Avatar
Jack it up and look.
Old 07-12-2013, 08:56 AM   #3
Kevo91's Avatar
Region: Utah
Im at work all I have is my little pos jack in the trunk, i didnt see anything just peeking under it. What should I be looking for? I would assume the car would have been all over the road if it was a ball joint
Old 07-12-2013, 09:11 AM   #4
1lowGT's Avatar
I have no idea. If you could just jack one side up so you can get your wheel off you might be able to see. Does it steer any different?
Old 07-12-2013, 09:23 AM   #5
My first thought would be the front sway bar end links. Just happened to my wife's DD honda. Bang and then a bunch of clanking as it hits off the unibody.
Old 07-12-2013, 09:24 AM   #6
1lowGT's Avatar
That's what I was thinking. Have you lowered your car?
Old 07-12-2013, 09:29 AM   #7
351stroker's Avatar
You can't check the ball joints or steering rods unless the car is jacked up. Better get it checked out. In the meantime, drive very nice.
351stroker is offline   Reply With Quote
Old 07-12-2013, 10:05 AM   #8
jjsg09's Avatar
---------- Post added at 12:05 PM ---------- Previous post was at 12:04 PM ----------
+1^ This is more than likely what it is. I read your post and it was the first thing that came to my mind.
Old 07-12-2013, 10:35 AM   #9
Kevo91's Avatar
Region: Utah
Thanks guys. And no I havent lowered, car is bone stock
Old 07-12-2013, 12:27 PM   #10
Kevo91's Avatar
Region: Utah
I looked at it the best i could without a decent jack. Everything looks and feels okay so maybe I just ended up hitting something on the road that I didnt see. Still gonna take it easy til I know for sure
02:15 AM
