Suspension mods - Mustang Evolution
Old 07-13-2013, 12:20 PM   #1
1lowGT's Avatar
Suspension mods
I just want to beef up the suspension a little bit I'll list some things from Maximum Motorsport's so reply with other things to help and thoughts on things listed below.
Subfame connectors.
4-point k member brace for stock k member.
Panhard bar.
Torque arm.
Upper control arms.
Old 07-13-2013, 12:28 PM   #2
onesickstang01's Avatar
If you run torque arm and panhard you won't need upper control arms. You want lowers for sure along with the subframe connectors you were looking for.
onesickstang01 is offline   Reply With Quote
Old 07-13-2013, 12:31 PM   #3
1lowGT's Avatar
Which would be better pan hard or torque arm
Old 07-13-2013, 12:46 PM   #4
They both have their benefits and act in different ways. But pair them together and you will have a great handling and nasty hooking car
Old 07-13-2013, 12:49 PM   #5
MidnightBlueGT's Avatar
Id get the subframes first
Old 07-13-2013, 01:23 PM   #6
1lowGT's Avatar
I need to get shocks struts first so i will probably get them first. And getting these below is that all i will need?
Gabriel Ultra/Shock/Strut - Front (G55681) | 2003 Ford Mustang GT 8 Cylinders X 4.6L SFI SOHC | AutoZone.com
Old 07-13-2013, 07:03 PM   #7
Mile high JDF's Avatar
IRS swap!!!
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-13-2013, 07:31 PM   #8
If you're going to go so far as to do all MM stuff and a TA/PB then why are you buying those? Just get the MM K member kit with coilovers and get your shocks from there.
Also the subframes are one of the few times where I'd recommend another brand than MM, get the Steedas. They come with plates that weld to the mounting points first, then the subframes weld to those. If you are near NJ call Wicked Motorsports, he gets deals on them and installs them all the time.
Old 07-13-2013, 07:33 PM   #9
Originally Posted by JDF View Post
IRS swap!!!
I want an irs swap!!
Old 07-13-2013, 07:37 PM   #10
I'm going to do one eventually... With a FTBR kit which should be mandatory for any IRS.
Old 07-13-2013, 07:41 PM   #11
I just need to find one that isn't super expensive.
Old 07-13-2013, 07:43 PM   #12
Find a 99 and upgrade the diff/halfshafts yourself. People think the 03/04 units are made of gold... with the beefed up stuff but wheel hop is the number one killer of IRS's and if you cure that the lighter duty units can take a pretty good beating.
Old 07-13-2013, 07:44 PM   #13
Gotta find one first lol
Old 07-13-2013, 08:01 PM   #14
There's one for $600 for sale in Colorado right now from a 99 Cobra.
Old 07-13-2013, 08:19 PM   #15
That's a good deal. Do the FTBR kit while its out and you should be GTG.
Old 07-13-2013, 08:39 PM   #16
I've already got an IRS. Unfortunately I didn't do the kit when I swapped because I was cramming everything into the last few weeks before going to the track. The guy with that one for sale is parting out his Cobra and asking dirt cheap prices for everything. I could pick up a 2000 Cobra R kit for $450, he has the amber taillights for $50, full midpipe back exhaust for $150 etc..
Old 07-14-2013, 10:40 AM   #17
1lowGT's Avatar
Well it's not that i would get everything mm i was just on their website because its basically all suspension. I wasn't saying that i would get all those. But i dont want to spend a whole bunch of money on coilovers a k member i just want to beef it up a little
Old 07-14-2013, 04:40 PM   #18
Get the UPR kit if you don't want to spend a lot of money and get a lighter k member and coilovers. You'll save almost a grand over MM but it won't go around corners as well. Still better than stock tho.
08:48 AM
