Transmission Temp - Mustang Evolution
Old 07-14-2013, 06:17 PM   #1
01mineralgreyv8's Avatar
Transmission Temp
My tr-3650 gets harder to **** when it gets hot, is there anything to do to keep it cooler?
---------- Post added at 08:17 PM ---------- Previous post was at 08:16 PM ----------
Originally Posted by 01mineralgreyv8 View Post
My tr-3650 gets harder to shift when it gets hot, is there anything to do to keep it cooler?
---------- Post added at 08:17 PM ---------- Previous post was at 08:17 PM ----------
Shift*
01mineralgreyv8 is offline   Reply With Quote
Old 07-14-2013, 06:52 PM   #2
2300turboford's Avatar
Try changing your tranny fluid
Old 07-14-2013, 07:04 PM   #3
Just did that last week when I put in a rebuilt trans
Old 07-14-2013, 09:38 PM   #4
So this brand new trans is getting hot as **** on you? Sounds like it might be an issue with the rebuild, do you have a warranty on it? What fluid did you use in this thing?
Old 07-15-2013, 12:33 PM   #5
v8pony's Avatar
+1 on warranty and I'm interested in what fluid you have in as well...my 3650 seems to be getting hot lately more than every, and recently I decided to try some pennzoil synchromesh, thinking about swapping back to Mobil 1 or trying Mercon V
2002 5spd GT
Feb 2013 Mustang of the Month
Old 07-15-2013, 12:41 PM   #6
Venomouz831's Avatar
They sell a transmission cooler on AM. But if its rebuilt I don't see why it would get hot and difficult to shift
)02 Gt, Founder of WE2G
Old 07-15-2013, 04:32 PM   #7
Transmission coolers are for autos...
Old 07-15-2013, 05:13 PM   #8
Didn't know his was manual
Old 07-15-2013, 05:31 PM   #9
v8pony's Avatar
Yea first post mentions 3650...OP I'd get back to whoever did the work on the rebuild and take it up with them..not much we can really help with, a rebuilt tranny SHOULD NOT be getting that hot..again what type of fluid did u put in the trans?
2002 5spd GT
Old 07-15-2013, 06:17 PM   #10
This could be a windage problem (too much oil) that you are experiencing. Try draining and refilling with 3.25 quarts instead of the 4 quarts that the factory recommends. There was a Technical Service Bulletin about the oil level being too high at the 4 quarts and causing shifting problems. Mobil 1 or Mercon V.
straybullitt is online now   Reply With Quote
Old 07-15-2013, 06:20 PM   #11
v8pony's Avatar
I used to have mine filled at 4qts from the factory and never had heating issues, I did have shifting issues (hard to put into gear)..when I drained and put back 3.2 qts the hard shifting stopped..
2002 5spd GT
Old 07-15-2013, 06:29 PM   #12
I guess my question to you guys would be, how do you know that your transmission is getting "too hot"? Do you have gauges? What I got from OP's post, is that the trans gets harder to shift when it is hot as opposed to when it is cold.
Old 07-17-2013, 09:42 PM   #13
Mobile 1 synthetic. They get hot when you run hard. That's pretty normal
---------- Post added at 11:42 PM ---------- Previous post was at 11:39 PM ----------
I can feel the shifter getting hot from the trans then it gets harder to shift. I might have too much fluid in it
08:45 PM
