help.... - Mustang Evolution
Old 07-14-2013, 10:19 PM   #1
Count Dragula's Avatar
Okay so I have a small miss at idle, under light acceleration it studders, and my rpms hang... whats going on with my car... no vac leaks.. idk what to do
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-14-2013, 10:42 PM   #2
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
Go put it on the comp and see what codes are thrown. If your missing at idle your missing when driving.
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 07-15-2013, 06:14 AM   #3
Check your plugs.when I had my 02 gt it was misfiring and studdering at idle and at low acceleration.turned out it was the plugs
Torchred2010gt is offline   Reply With Quote
Old 07-15-2013, 06:34 AM   #4
cliffyk's Avatar
A stuck or sticking EGR valve can cause this, and is a common problem on higher mileage older cars--it will often not trigger a DTC. Another potential cause is removal of the MAF screen...
Old 07-15-2013, 07:12 AM   #5
Havent seen you in a while on here! I had a mustang expert check everything and he said a lomg shot will be plugs, and he is thinking an injector is getting stuck. He unplugged them one at a time and when he got to number 4 and plugged if back up the miss stopped and slowly came back. He thinks it could be that. He checked the maf and its good. Checked the egr and its good
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-15-2013, 07:48 AM   #6
cliffyk's Avatar
Sounds like a sticking injector--they can be cleaned, though you can often buy a whole set of stock injectors for less than it would cost to clean them.
I have been tapering off the Mustang forums since I sold mine, I will not be going away just cutting back...
Old 07-15-2013, 07:56 AM   #7
Yeah he said it was probably staying closed a little too long. I want to supercharge in the future so I may go with 42 or 39 pound anyways
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-15-2013, 08:04 PM   #8
Okay so I had extra plugs laying around so I changed those first and pulled the others and they had dirt on them.....? Wtf lol so I changed them and now my car is more smooth under light acceleration and idles way better!
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
08:10 AM
