Key fab problem - Mustang Evolution
Old 07-15-2013, 12:09 AM   #1
joebyrne27's Avatar
Key fab problem
Seeing if you guys can help me, my 99 gt only the driver side lock and unlocks ?
Now the passenger side door you lock it or unlock it several times u see it wants to move, but struggles inch by inch. And will not do its job
Have any of you guys experienced this, or maybe know what to do? Thanks !
joebyrne27 is offline   Reply With Quote
Old 07-15-2013, 10:07 AM   #2
JimmyMosqueda's Avatar
WD 40? Lol
JimmyMosqueda is offline   Reply With Quote
Old 07-15-2013, 04:49 PM   #3
lilgramboy's Avatar
my drivers side does this... I think it might be the motor going for the locks... I'm not sure
lilgramboy is offline   Reply With Quote
Old 07-15-2013, 05:01 PM   #4
You are correct.
Old 07-15-2013, 05:45 PM   #5
Pull the door panel off and see if it works without that possibly binding it up. Then go from there.
2000 Mustang GT Steeda #0048
Old 07-15-2013, 10:15 PM   #6
lilgramboy's Avatar
mine does it when the door is off.. it works like 3 times in a row but then doesn't work for like 5 min then it works a couple times
Old 07-16-2013, 08:48 AM   #7
Does the same thing using the actual door switch too? Might be a flaky wire, might be the actuator going out. You could always swap the driver's side actuator to the passenger's side and see if it still does it. If it does its a wire, if not just get a new actuator, replace and dunzo.
Old 07-16-2013, 09:37 AM   #8
lilgramboy's Avatar
yea with the fab or with the switch and how much are accuators?
Old 07-21-2013, 11:58 PM   #9
joebyrne27's Avatar
When I re order a new one is there a right or left actuator ?
07:17 AM
