Bad knocking - Mustang Evolution
Old 07-15-2013, 09:25 AM   #1
Gobabygo67's Avatar
Bad knocking
Whenever I put my car in first gear and accelerate it makes a bad knock after I let go of the clutch and give it gas. It also makes the same knocking noise at times when I turn my wheel and its also the cause of whatever vibration problems I'm having when I'm around 65 mph. I checked my u joint out and it was perfectly fine so if anyone has advice to help me out I'd greatly appreciate it!!
Gobabygo67 is offline   Reply With Quote
Old 07-15-2013, 08:25 PM   #2
1996mustang's Avatar
Check your control arms. Check suspension parts also check the tranny mount
Old 07-15-2013, 09:43 PM   #3
Gobabygo67's Avatar
Any specific suspension parts to check?
Old 07-15-2013, 09:48 PM   #4
i would say check the control arms, they would have play, another part to check is the strut mount bushings, they may be loose or they are probably bad, if it does it when u gas it after you drop the clutch it could be a motor mount however i doubt it would vibrate the car at 65mph that is more a suspension issue.
Old 07-15-2013, 09:54 PM   #5
Gobabygo67's Avatar
Ok thank you! Ill check it out in the morning to see
10:17 AM
