Good clutch for t-45? - Mustang Evolution
Old 07-16-2013, 01:20 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
It's for my 2001 DD and I drive a lot so I want something smooth but still a good strong clutch.. Any opinions or stories?
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-16-2013, 01:22 PM   #2
King Cobra
/thread
Old 07-16-2013, 01:23 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
King Cobra
/thread
Ware can I get that?
2001 GT - True Blue
Old 07-16-2013, 01:27 PM   #4
Venomouz831's Avatar
Excedy is what I went with and no complaints whatsoever. Holds great, much stiffer but it's better than stock
)02 Gt, Founder of WE2G
Old 07-16-2013, 01:27 PM   #5
The google, she knows much.
Old 07-16-2013, 01:30 PM   #6
slow281
sixpac's Avatar
Region: Nebraska
The one I have now is too stiff.. I want the girl to be able to drive it..
2001 GT - True Blue
Old 07-16-2013, 01:37 PM   #7
Then oem is maybe what you're looking for. I believe all aftermarket are stiffer than stock
Old 07-16-2013, 02:05 PM   #8
slow281
sixpac's Avatar
Region: Nebraska
What about a stage 1
2001 GT - True Blue
Old 07-16-2013, 03:00 PM   #9
Mile high JDF's Avatar
My exedy stage 1 is as stiff as the stock one and grips pretty good.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-16-2013, 03:01 PM   #10
A lot of clutch threads today. COBRA
Old 07-16-2013, 03:39 PM   #11
The King Cobra is rated much higher than OEM but retains the OEM clutch pedal stiffness. Again... get the King Cobra...
Old 07-16-2013, 04:00 PM   #12
White03GT's Avatar
+1000
White03GT is offline   Reply With Quote
Old 07-16-2013, 08:11 PM   #13
slow281
sixpac's Avatar
Region: Nebraska
This is my only one lol I just wanted to know what people got..
---------- Post added at 09:11 PM ---------- Previous post was at 09:10 PM ----------
Good life span on those (assuming I can drive good)
2001 GT - True Blue
Old 07-16-2013, 08:16 PM   #14
A big question that hasn't been asked is what are the plans for the car? If it's just a DD then why go with an aftermarket clutch?
Old 07-16-2013, 08:22 PM   #15
deadsp0t's Avatar
Center Force Dual friction.. Google it..
That's unimpressive
Old 07-16-2013, 08:32 PM   #16
slow281
sixpac's Avatar
Region: Nebraska
Well exhaust/tuner/MGW/373/cai/TB/plenium/315s on the back is what will be done with it, but still a DD
---------- Post added at 09:32 PM ---------- Previous post was at 09:28 PM ----------
I'm not spending 400$ on a clutch..
---------- Post added at 09:32 PM ---------- Previous post was at 09:32 PM ----------
What's considered oem tho perfection clutch?
2001 GT - True Blue
Old 07-16-2013, 08:40 PM   #17
10.5" King Cobra clutch kit
11" King Cobra clutch kit
NOTE, and I'm mad I forgot about this, YOU HAVE A CHANGEOVER YEAR as far as clutches go. Check the trans code on your door sticker. If you have a 6 for the trans code you use the 10.5" clutch, if not you use the 11" clutch. Or just get a new flywheel for whatever clutch you want lol.
Old 07-16-2013, 08:51 PM   #18
Well just any stock replacement clutch would do. If you want peace of mind then you could go with a stage 1 clutch. If you don't plan on a crapload of power then a stage 2 or up is not really necessary.
Old 07-16-2013, 08:57 PM   #19
He should just get either of the KC clutches I posted. Whatever one his car calls for since 2001 was the bastard changeover year.
Old 07-16-2013, 09:11 PM   #20
slow281
sixpac's Avatar
Region: Nebraska
Well it's the t-45 so wouldn't it be what ever one fits that?
2001 GT - True Blue
Old 07-16-2013, 09:12 PM   #21
Stock one should hold just fine. But biased against the King Cobra clutches though.
Old 07-16-2013, 09:13 PM   #22
slow281
sixpac's Avatar
Region: Nebraska
Thank you for the post.. Helps a lot and a lot more cost effective.. Lol
2001 GT - True Blue
Old 07-16-2013, 09:16 PM   #23
Like I said in the other post, you have to check your trans code. If its the t-45 its an early run 2001 and will have the 10.5" clutch but are you SURE you have a t-45 because 2001 is when the 3650s started going in.
Old 07-16-2013, 09:20 PM   #24
slow281
sixpac's Avatar
Region: Nebraska
Nah I ran the vin and I'm pretty sure it's a 6.. I have an 02 body with a 00 drivetrain, still 19lb injectors and plastic crossover on the intake..
2001 GT - True Blue
Old 07-16-2013, 09:27 PM   #25
Ok now I'm confused... if you ran the VIN on an 02 it would come back as a 3650... so not a 6. You also said you have a 2001 in your original post... If it is indeed a 00 drivetrain it should be a t-45 but you should probably make sure.
You can also just get whatever flywheel you want for the clutch you get. You should get a new flywheel anyway or at least get yours resurfaced so just get a 10.5" flywheel and get the cheaper KC clutch.
Old 07-16-2013, 09:45 PM   #26
slow281
sixpac's Avatar
Region: Nebraska
I was saying......... I have all the body/interior things an 02 would and drivetrain of a 00 I tell everyone that because 01 is so fuked up.. I've had so many people say well you have the double din CD player and the side scoops it has a 3650 and 21lb injectors.. Which is wrong..
2001 GT - True Blue
Old 07-16-2013, 09:52 PM   #27
Ok, yeah they way you say that is very confusing. You have an early run 2001 model then so get the $161 clutch and call it good. Also, get that intake swapped out to an updated one stat. Last thing you'll want is for that thing to split and puke coolant all over the damn place and it will eventually. If your luck is anything like mine it'll be on your way to work on a day you REALLY can't be late, in traffic and you'll cause a huge logjam and make a bunch of other co-workers late too including your boss.
Old 07-16-2013, 10:02 PM   #28
slow281
sixpac's Avatar
Region: Nebraska
I will.. Havnt had the funds..
2001 GT - True Blue
Old 07-16-2013, 10:04 PM   #29
I just sold a metal crossover PI intake for $100 shipped which is about the going rate. Don't waste your money buying one new. Also for the love of god don't get a Dorman...
Old 07-17-2013, 08:43 AM   #30
slow281
sixpac's Avatar
Region: Nebraska
Alright I hope I can find one that cheap..
2001 GT - True Blue
Old 07-17-2013, 05:12 PM   #31
Go on the corral classifieds, $100-$125 shipped is the going rate for them, just make damn sure you don't get a Dorman.
Old 07-17-2013, 10:36 PM   #32
slow281
sixpac's Avatar
Region: Nebraska
What's so bad about them.. Just wondering lol.
2001 GT - True Blue
Old 07-17-2013, 10:51 PM   #33
2300turboford's Avatar
Their a pos that will crack to
Old 07-18-2013, 07:25 AM   #34
The coolant crossover on the old PI intakes is plastic and after awhile it WILL split and puke coolant all over your motor/the ground. Have fun when it happens and you need to get a flatbed to get you home...
Old 07-18-2013, 09:30 AM   #35
slow281
sixpac's Avatar
Region: Nebraska
I'll by one and drive around with it thin the trunk lol..
2001 GT - True Blue
06:55 AM
