Koni Yellow Sport Shocks vs Tokico Illuminas vs Bilstein HD - with H&R SS springs? - Mustang Evolution
Old 07-16-2013, 02:03 PM   #1
I currently have Tokico Illuminas Adjustable shocks/struts on my 2000 GT paired with H&R SS springs. I am using the foxbody version in the front of the car.
Anyhow, the car seems to have a lot of body roll / nose dive under hard braking and cornering, yet it is bone jarringly harsh over bumpy roads.
Would switching to either the Koni Yellow Sport adjustable shocks/struts or Bilstien HDs help? Or is the problem with my H&R SS springs?
2000 Atlantic Blue GT
paradigm is offline   Reply With Quote
Old 07-16-2013, 03:12 PM   #2
fastmustangs1's Avatar
Either Koni sports of Bilstein HD I would choose over Tokicos.
I run Koni sports and love them.
fastmustangs1 is offline   Reply With Quote
Old 07-16-2013, 06:40 PM   #3
May I ask why you are using the Foxbody version?
Old 07-16-2013, 07:07 PM   #4
Mile high JDF's Avatar
Foxbody struts are smaller but use the same mounting points so they are ideal for really low cars.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-16-2013, 07:10 PM   #5
1996mustang's Avatar
Really? Makes me wonder if i should invest in some. Hows it handle for lowered cars?
Old 07-16-2013, 07:12 PM   #6
Yep. The SN-95s and New Edges are a modified Fox chassis called the Fox 4 or something like that. I haven't personally put fox struts on so I honestly don't know.
Old 07-16-2013, 07:20 PM   #7
Exactly why I am using them. I wonder though if these foxbody struts are valved differently to support a lighter weight car, thus not supporting my heavier SN95 as well?
There is a local deal for Koni Sport Kit which consists of the Koni Yellow Shocks and Koni Sport Springs but for the foxbody... I was thinking I shouldn't have an issue with the shocks/struts, but now thinking it through, it might not be a good idea? I was going to sell off the springs and just use the shocks/strut.
Old 07-16-2013, 07:23 PM   #8
Interesting. I didnt know that. I wonder if the valving is different and that is the reason OP is having ride quality issues. I ask this because I just bought a set of Illuminas and hope to hell that the ride is not as bad as OP is experiencing.
Old 07-16-2013, 07:25 PM   #9
Also to anyone here that have used the illuminas - are you able to twist the adjustment knob continuously? I have noticed no actual stopping point past notch #5... like it just keeps spinning. Is this normal?
EDIT - after reading it appears that this is normal for the illuminas adjustment.
How about the Koni Yellows - can you adjust them on the car or do they need to be removed from the car? From reading about them on different cars, it looks like the fronts are adjusted on the car via a top knob, and the rears must come off? I would hate to have to pull them everytime I needed to adjust...
Old 07-16-2013, 07:30 PM   #10
Yeah the shocks and struts wont have much to do with the swaying but the excessive diving isn't right. What setting do you have them at?
Old 07-16-2013, 07:38 PM   #11
Here are a shot of my rear Konis.
Old 07-16-2013, 07:43 PM   #12
Set to 5 in front and 3 in rear now - I just set them like this this past weekend. I haven't pushed the car hard since to really comment on nose lift/dive and body roll yet. Before the front was set to 3 and rear to 3.
Can you adjust the rears on the car, or do they need to be removed? How about the front - adjustable on the car?
Also how difficult was your rear panhard bar install? I have mine sitting here waiting to go on for over a year now.
10:13 PM
