BBK THROTTLE BODY - Mustang Evolution
Old 07-16-2013, 06:24 PM   #1
lilgramboy's Avatar
BBK THROTTLE BODY
So thinking about getting the 78mm throttle body but not to sure if it would be the right thing.. lots of people say no because I only have a tuner, intake manifold, and cold air in the engine right now, but others say it still helps alot and do it... any opinions or help? thanks
lilgramboy is offline   Reply With Quote
Old 07-16-2013, 06:45 PM   #2
MidnightBlueGT's Avatar
Its a good tb and plenum combo. And it won't really be used all the way because not as much airflow coming in. But its worth it if you ever go f/i in the future.
Old 07-16-2013, 07:18 PM   #3
lilgramboy's Avatar
not as much air flow? it makes more air flow come in
Old 07-16-2013, 08:11 PM   #4
Mile high JDF's Avatar
He meant to say air velocity. The engine doesn't generate enough vacuum to suck in air through such a big hole. Usually 70mm is recommended for a N/A motor because it helps maintain air velocity while still flowing more air than the stock throttlebody. If you read through the Beginners Guide to Bolt-Ons in the stickies section it has a chart comparing the air flow you get out of various plenum and throttlebody combos.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 07-16-2013, 08:15 PM   #5
That extra amount isnt going to be used because that extra amount isnt being made.
Old 07-16-2013, 08:18 PM   #6
http://www.paladinmicro.com/pmicro.p...ufabFlow01.htm
Old 07-16-2013, 08:28 PM   #7
lilgramboy's Avatar
would it be gains in power still with more air if I will upgrade more engine things or would it be loss of power
Old 07-16-2013, 08:48 PM   #8
You won't see much of a power difference in the butt dyno. If you do some major engine work to make it breathe or go F/I then the 78mm might worth it.
Old 07-16-2013, 09:01 PM   #9
lilgramboy's Avatar
fuel injectors is what you mean right? and how big of injectors would you say?
Old 07-16-2013, 09:07 PM   #10
F/I=Forced Induction IE Supercharger/Turbocharger.
Old 07-16-2013, 09:43 PM   #11
lilgramboy's Avatar
oh I was going to say I never really heard of fuel injectors effecting throttle body's lol but yes I don't think I'm going with a super or turbo any time soon
Old 07-16-2013, 09:54 PM   #12
IMO, just get the Trick Flow plenum and Dragon 75mm TB. Done and done. The TFS plenum is EASILY the best bang for the buck plenum out there and the plenum should be upgraded right away as its the same one that comes on the NPI cars and not exactly optimal.
Old 07-17-2013, 06:44 AM   #13
AgentOrange's Avatar
I have the BBK 78mm on my car and it hardly makes a difference. I doubt any of them do. There are better mods for the money (gears!)
AgentOrange is offline   Reply With Quote
Old 07-17-2013, 06:53 AM   #14
Gotta upgrade the plenum too for anything even slightly noticible. Lets you pull harder up top at least.
Old 07-17-2013, 08:40 AM   #15
lilgramboy's Avatar
how much is the trick flow plenum and the dragon 75mm?
Old 07-17-2013, 04:59 PM   #16
The Google machine... use it.
11:25 PM
