Ideas for some relatively cheap hp gains? - Mustang Evolution
Old 07-17-2013, 01:34 AM   #1
Raf5050's Avatar
I have about $1000-$1500 to put into my 04 GT right now, and I was wondering if anyone knew some cheap and easy mods to gain hp such as exhausts, gears, intakes, etc... Just asking for suggestions if anyone knows what's best.
Raf5050 is offline   Reply With Quote
Old 07-17-2013, 01:45 AM   #2
MidnightBlueGT's Avatar
Full exhaust, gears, tuner
Old 07-17-2013, 02:23 AM   #3
Slow4V's Avatar
[QUOTE="Raf5050;1723601"]I have about $1000-$1500 to put into my 04 GT right now, and I was wondering if anyone knew some cheap and easy mods to gain hp such as exhausts, gears, intakes, etc... Just asking for suggestions if anyone knows what's best.
1. gears ( 410>373 )
2. Short shifter
3. Tuner
4. Suspension ( Rear control arms / Upper ) ( Springs ) ( Full length subframe connectors )
5. Long tube headers , X Pipe
6. Typhoon manifold , Plenum , 70mm TB, Cold air intake
That's what I would do if I started with a Gt again..
---------- Post added at 02:23 AM ---------- Previous post was at 02:22 AM ----------
Gears will be best bang for buck ..
You will notice it more than other mods
Normal gear install is 150+ labor which should be no more than 300$
Old 07-17-2013, 07:42 AM   #4
AgentOrange's Avatar
Slow pretty much covered it, though I'd avoid headers and intake manifold until you have everything else he mentioned. Stock intake and exhaust manifolds flow sufficient for a bolt-on 2v. Start with exhaust and a cold air intake. You'll love the sound of the exhaust, and the CAIs offered by American Muscle are super cheap, even moreso with your forum discount. Gears will give you the biggest improvement in acceleration.
AgentOrange is offline   Reply With Quote
Old 07-17-2013, 07:45 AM   #5
There is a sticky called "Beginner's Guide to bolt ons" at the top of the forum.
2000 Mustang GT Steeda #0048
10:43 AM
