High idle - Mustang Evolution
Old 07-17-2013, 11:43 AM   #1
blackdreams15's Avatar
High idle
Put a new motor in my 02 and it idles very high put after a few seconds it levels out but if you tap the gas it jumps up to about 6,000 and levels back out reallyslow! Any suggestions?
blackdreams15 is offline   Reply With Quote
Old 07-17-2013, 11:50 AM   #2
cliffyk's Avatar
First check that the throttle stop screw is properly adjusted (here's how), then test the IAC--here is how to do that...
Old 07-17-2013, 11:58 AM   #3
slow281
sixpac's Avatar
Region: Nebraska
Good info, if mine dies or drops when I come to a stop sign could it be my iac? Like I'll be in 3/4 and drop to nutral an it might die.. Buy just sitting its fine or if I downshift and drop speed slowly..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-17-2013, 12:02 PM   #4
Thanks for the info. Il give it a try soon as i get a chance to get back on it
Old 07-17-2013, 12:10 PM   #5
cliffyk's Avatar
Yes, the IAC is the primary device, as its name implies, that the PCM uses to control the idle. When rolling to a stop the PCM keeps the idle high while the car is moving to ensure more than enough power steering system pressure to keep the power brakes working as they should, one the car stops the PCM returns to normal idle speed. If the IAC if dead/dying this process will mess up.
Test it as in the link I provided above...
Old 07-17-2013, 02:02 PM   #6
slow281
sixpac's Avatar
Region: Nebraska
And there's no way to clean that just replace it?
2001 GT - True Blue
Old 07-17-2013, 09:46 PM   #7
cliffyk's Avatar
Ford, and my experience, says no--at best cleaning it is a temporary fix, just replace it and be done...
from the shop manual:
Old 07-21-2013, 05:36 PM   #8
slow281
sixpac's Avatar
Region: Nebraska
Bought a new one lol..
2001 GT - True Blue
02:13 PM
