fuel injectors - Mustang Evolution
Old 07-17-2013, 07:31 PM   #1
Count Dragula's Avatar
fuel injectors
So I have a clogged injector and my friend totalled his mustang this week. He has 42 lb injectors and was going to sell them to me seeing that I was supercharging anyways. Will a need a tune? I have a 255 fuel pump now.
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-17-2013, 07:36 PM   #2
Rm360's Avatar
Unless your adding more air your current tune will be fine
Old 07-17-2013, 07:38 PM   #3
From my understanging the computor will only send so much right? So it wont send that much fuel just because bigfer injectors unless it needs to??
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-17-2013, 07:43 PM   #4
Rm360's Avatar
You sir are correct!! If you upgraded to FI or cams and heads , really anything to take in more air them you would want to retune to send more fuel, only at that time will you need a tune.
Old 07-17-2013, 07:44 PM   #5
Okay good! Are they easy to change and should I do fuel rails too?
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-17-2013, 07:51 PM   #6
Rm360's Avatar
They are pretty easy a bit time consuming but not to bad , you don't have to change the fuel rail , the stock rail can handle upwards of 500hp
Old 07-17-2013, 08:09 PM   #7
Ive looked around on google and ive seen people say that I need a tune and matching maf... I dont want all that right now lol
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-17-2013, 08:29 PM   #8
Bigger injectors=tune or "calibrated" (hacked) MAF. Think about it if you don't get a tune the computer will be firing the 42lb injectors just like its firing the stockers so you'll be dumping over double the amount of fuel into the cylinders for the same amount of air. If it does run it'll be PIG rich. Hell the cars with the pink stock injectors even run a little rich because Ford went to 21lb injectors and didn't change the tune at all which was written for the 19s in the earlier PI cars.
Old 07-17-2013, 08:37 PM   #9
So can I get a flash tuner and use 42?
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-17-2013, 08:42 PM   #10
If its a really good deal I'd buy them now and then put them on the shelf until you do the supercharger and install them then with a dyno tune. There is no need for them now.
Old 07-17-2013, 08:43 PM   #11
Well I have a clogged one lol
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-17-2013, 08:48 PM   #12
I'd check the Evilbays. There is a single pink injector which is what you have for $50 shipped on there right meow.
1985 2004 Ford 5 4 5 0 4 6 Fuel Injector Motorcraft cm 5041 Fotz 9F593 Da | eBay
Old 07-17-2013, 08:53 PM   #13
Rm360's Avatar
I was led to believe that the fuel pressure is measured at the rail not the injector and if you put a 42 lb injector in it would run like a 21 just not as effecint, isn't the injector size just determined by the size of the diameter of the hole?
Old 07-18-2013, 11:13 AM   #14
Which 24 lb injectors should I get? 24 is stock right?
---------- Post added at 01:13 PM ---------- Previous post was at 01:12 PM ----------
Nevermind 21...
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
04:57 AM
