need hood help - Mustang Evolution
Old 07-17-2013, 08:49 PM   #1
Doe_Rae_mi's Avatar
Im prolly ganna buy a Hood from someone on Craigslist, what all will I need for the Hood to fit and work on my car? Hood pins? It's aftermarket
Old 07-17-2013, 08:51 PM   #2
Count Dragula's Avatar
Depends what hood... if it has holes for hood pins then yes. If not it should be a drop in and just a little adjusting
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-17-2013, 08:57 PM   #3
Rm360's Avatar
If its a bolt on hood then you should be able to bolt on , adjust, and be done, you may have to drill out your hinges to get proper alignment but that's really it! Using pins is dependent on the type of hood and weight, but I recommend using pins if you plan on doing any drag racing or a lot of highway driving just to be safe!
Old 07-17-2013, 08:59 PM   #4
Doe_Rae_mi's Avatar
If I give you pics will you guys be able to tell?
Old 07-17-2013, 09:02 PM   #5
Yes
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-17-2013, 09:04 PM   #6
Doe_Rae_mi's Avatar
Here is one of them,wouldn't let me add the others,he said there are props that hold it up or something like that
Old 07-17-2013, 09:06 PM   #7
Rm360's Avatar
Looks like a cobra r style hood and yes you will need to drill for the hood pins
Old 07-17-2013, 09:08 PM   #8
Beat me to it lol
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-17-2013, 09:10 PM   #9
Doe_Rae_mi's Avatar
Here's the prop thing
Old 07-17-2013, 09:12 PM   #10
I say dont use that... just more work on your end for drilling and fitting it right.
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-17-2013, 09:12 PM   #11
Rm360's Avatar
That's diffrent! ( the prop)
Old 07-17-2013, 09:13 PM   #12
Doe_Rae_mi's Avatar
Well it's already on it lol. I'm lost bro. He said it latches also but has pins on it
Old 07-17-2013, 09:15 PM   #13
Rm360's Avatar
You can remove the prop and get some hood struts , and just drill holes for the pins! Not hard at all! What are you lost on?
Old 07-17-2013, 09:15 PM   #14
You would still need to drill and fit to your car. The pins are basically just a backup device if the latch breaks which it probably wont lol the supporting things on the side are pointless because your car now has a prop so I dont see the need in a thing like that..
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-17-2013, 09:15 PM   #15
Doe_Rae_mi's Avatar
He said there's pins on it as well lmao. So I think they are already installed?
Old 07-17-2013, 09:18 PM   #16
You would just need to put the anchor for the pins on your car now
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-17-2013, 09:19 PM   #17
Rm360's Avatar
The plates are installed on the hood you have to drill through your frame to install the pin , ill get you a couple pics be right back!
Old 07-17-2013, 09:19 PM   #18
Doe_Rae_mi's Avatar
Oh!!! Sounds scary lol
Old 07-17-2013, 09:33 PM   #19
Rm360's Avatar
Pic one plate on hood , pic two pin drilled through frame,pic three is a custom mounting bracket I made and welded to the frame because I didn't want to drill through the frame
ID:	118973   Click image for larger version
Old 07-17-2013, 09:45 PM   #20
Doe_Rae_mi's Avatar
Okkkk I see now, thanks man!
Old 07-17-2013, 09:56 PM   #21
Rm360's Avatar
NP!
03:39 AM
