PI Intake Actual HP Gains - Mustang Evolution
Old 07-18-2013, 10:53 AM   #1
ty98gt's Avatar
Hey guys, my 98gt is still all npi and im curious as to whether upgrading just the intake to PI would be worth it. Ive researched around and found people saying you can gain up to 30hp with a tune but ive also seen people say its a worthless mod without the heads/cams, so im kinda confused.. My car is already heavily modded and im pretty sure its been tuned by the previous owner, so would this help me get better hp gains from just the PI intake? If any gains at all?
-PS, a full pi swap is not an option at the moment. Maybe in the future but right now I don't have the time nor the cash...
Engine/drivetrain mods: Pro 5.0 Short Shifter, Dragon Plenum-75mm, Accufab TB-70MM, K&N FIPK GEN.2 Air Intake, Bassani Cat Back Exhaust,Bassani Catted X Pipe, 3.73 FRPP Rear Gears,Ford Racing TA Rear Diff Cover,
Bunch of suspension goodies
ty98gt is offline   Reply With Quote
Old 07-18-2013, 03:40 PM   #2
ty98gt's Avatar
Bump
Old 07-18-2013, 04:10 PM   #3
White03GT's Avatar
Its worth it if you look at it in the sense you'll be closer to a full pi swap. I would if I were you, you won't feel the power increase due to there being very little of it, but you will be closer to a full swap lol.
White03GT is offline   Reply With Quote
Old 07-18-2013, 06:27 PM   #4
98vertgt's Avatar
I would say not 30hp but maybe 10-15 with a tune. I have the pi intake and Bama doesn't tune for them so I don't know where you'd get a tune unless a dyno tune.
98vertgt is offline   Reply With Quote
Old 07-18-2013, 07:22 PM   #5
cliffyk's Avatar
It is not a worthless mod without doing the heads, however it will be worth less. It is the PI heads and cams that make 99.44 % of the added HP, the intake was redesigned so as to feed the better flowing PI heads--by itself it will not add much...
Old 07-18-2013, 07:27 PM   #6
White03GT's Avatar
+1k
Old 07-19-2013, 07:21 AM   #7
Actually the NPI intake is pretty terrible... MHS discovered that the NPI heads are not all that bad and if all you do is the PI intake/Cams you won't be all that far away from the full PI swap... The NPI cams are the biggest culprit out of the 3. I would honestly just do the full PI swap though. Can be done in a weekend no problem and no tune required at all.
Old 07-19-2013, 01:26 PM   #8
ty98gt's Avatar
I keep hearing that the intake is pretty bad too, so I figured if i could pull out around 15hp by swapping intakes, that it wouldn't be a bad idea..
Would having a tb/plenum combo, cai and a tune increase my chances of gaining hp with only the pi intake?
Old 07-19-2013, 04:58 PM   #9
1996mustang's Avatar
Minimal gains to say the least. Take it from me and scotty pi swap is the better way to go or atleast swap the ibtake cams of a pi head. I have pi heads and intake much more beneficial to our years since we will put out more hp than a stock 99-04 due to our compression increase from the heads. So instead of the 215hp and 285tq to the fly we go to roughly 285-290hp to the fly and 300+ to possible 400 tq to the fly. Note i said flywheel due to i have yet to dyno mine with all the other goodies i have added on. I would maybe say 250bhp ish for a full pi head swap
Old 07-20-2013, 11:21 AM   #10
ty98gt's Avatar
Maybe I should just save for the full swap, or go to back to my original plans to supercharge. I would have done the full pi swap by now, but my car is my dd and its hard to find time for a job like that...only time and money will tell lol
Thanks for the info guys
08:46 AM
