1998 Cruise Control - Mustang Evolution
Old 07-21-2013, 05:36 PM   #1
XSlashDashX's Avatar
1998 Cruise Control
98 GT 5 speed
Okay so cruise control never worked since I got the car. I looked under the hood and the cable seems fine. What else could be the problem?
Old 07-21-2013, 07:36 PM   #2
Cruise motor?
Old 07-21-2013, 08:32 PM   #3
1996mustang's Avatar
Fuse? Relay? Start looking for power first
Old 07-21-2013, 08:46 PM   #4
Fuse is fine. So is relay.
Old 07-21-2013, 09:07 PM   #5
How are they fine? Do they have power? Have u tested it with a test light? Just cause a fuse looks ok does not mean it doeant have a hairline crack that made it blow and looks like its ok. Did u test for power with a test light. If so then test for power going to the motor after u verify power going from and to the relay as well
Old 07-22-2013, 04:33 PM   #6
Newbie when it comes to the Gt. so I looked under the hood and saw there was a hole. Picture below. Is that normal? Also took photos under the dash and there's a plug missing?
ID:	119923   Click image for larger version
ID:	119925   Click image for larger version
ID:	119927   Click image for larger version
ID:	119929   Click image for larger version
ID:	119931   Click image for larger version
Old 07-22-2013, 06:18 PM   #7
The hole is normal. I did however notice that maybe the brake switch has alot to do with the cruise control. If u have the wrong switch cruise probably wont work due to that the brake switch is used for cruise control as well
Old 07-22-2013, 07:06 PM   #8
Whatever it takes, need cruise control fixed lol. Where's brake switch located? And cost of replacing it?
08:48 AM
