running to rich at idle - Mustang Evolution
Old 07-25-2013, 10:45 AM   #1
im running way to rich at idle and at part throttle. i had a "custom tune" done by rick at amazon tunning solutions but now he is MIA. im running 30lb injectors with my stock mass air meter could that be the problem? evan with the custom tune? and i did raise commpression too. any ideas? or a new place that does email tuning?
iquiksn95 is offline   Reply With Quote
Old 07-25-2013, 11:10 AM   #2
Rapinator126's Avatar
email tune was where u made your mistake. whats all done to the car?
Old 07-25-2013, 11:26 AM   #3
1lowGT's Avatar
What else is done that you have 30lb injectors
Old 07-25-2013, 11:38 AM   #4
well flat top pistons,patriot stage 2 heads,elderbrock victor jr intake,bbk upper plenum,70mm throttle body,mac long tubes,mac pro chamber mid pipe,2800 stall,4:10 gears
Old 07-25-2013, 11:41 AM   #5
1lowGT's Avatar
Okay i thought maybe you had bolt ons and bigger injectors. Maybe try getting it dyno tuned . Stock cams?
Old 07-25-2013, 11:47 AM   #6
Count Dragula's Avatar
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-25-2013, 11:48 AM   #7
yeah stock cams for now. but i was waiting on the dyno tune till i put in a stroker that i want to put in as soon as i get the cash. car runs great full throttle but runs real rich part throttle and idle was thinking of going to the lighting maf sonsor and see if that would help
Old 07-25-2013, 12:11 PM   #8
1lowGT's Avatar
Well how long will it be till then?
---------- Post added at 01:11 PM ---------- Previous post was at 01:11 PM ----------
Originally Posted by DSG2003 View Post
.. One upped you.
Old 07-25-2013, 12:28 PM   #9
cliffyk's Avatar
You cannot just swap MAFs (or injectors) and hope to get lucky. The MAF curve and injector settings in the tune have to be coordinated to make them work together.
Have you data logged any operating parameters, do you know what the short term fuel trims look like when idling and running at part throttle?
How rich is it, do you have a wideband O2 system?
Have you changed anything since the tune was written/flashed?
Old 07-25-2013, 12:41 PM   #10
yes i have a wide band and it reads 10.5 at idle and 11.3 at part throttle. i have data log it before to the guy that was doing my tunning but it wouldnt change. and i also tried to go back to the stock 19lb injectors and same problem at idle and at part throttle. but lean at wot
Old 07-25-2013, 01:04 PM   #11
cliffyk's Avatar
You need to see what the short term fuel trims (STFT) look like, failing front O2 sensors will make the engine run rich┬╣ and as long as the STFTs are less than +25% there will be no DTC thrown...
┬╣ -- As narrowband O2 sensors fail their output voltage drops. In closed loop mode the PCM interprets this as the mix being too lean and tries to richen it by adding fuel (via the short term fuel trims). Running rich for an extended period will damage narrowband sensors.
Old 07-25-2013, 01:51 PM   #12
.. One upped you.
Haha nah I posted in a exhaust thread and it came to this one. I didnt catch it till it was too late lol
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
06:23 PM
