Going for cammed - Mustang Evolution
Old 07-25-2013, 11:54 PM   #1
MidnightBlueGT's Avatar
Title says it all!
I really love the aggressive and mean sound of cams. Thing is im almost clueless about them lol. I dont really know the difference between each one besides it alters the timing and all that.
Which cams would be best for a stang like mine? One thats a daily driver and will be boosted eventually. Leads me to another question, ive heard about blower cams, can those be used on n/a engines safely?
Thanks for all the help!
Old 07-26-2013, 01:16 AM   #2
calebnaasko's Avatar
I don't know a whole lot either but I'd check out the stage 1 comp cams on American muscle.
calebnaasko is offline   Reply With Quote
Old 07-26-2013, 05:53 AM   #3
Slow4V's Avatar
Originally Posted by MidnightBlueGT View Post
Title says it all!
I really love the aggressive and mean sound of cams. Thing is im almost clueless about them lol. I dont really know the difference between each time besides it alters the timing and all that.
Which cams would be best for a stang like mine? One thats a daily drive and will be boosted eventually. Leads me to another question, ive heard about blower cams, can those be used on n/a engines safely?
Anderson is good
Old 07-26-2013, 10:35 AM   #4
Thanks guys. Any other help??
Old 07-26-2013, 04:35 PM   #5
None??
Old 07-26-2013, 06:30 PM   #6
Stage 2 comps
Old 07-26-2013, 06:35 PM   #7
Stage 2 comps
I read those but it says the stage 1 is better for a dd and stage 2 for f/i. I want both lol. You think the state 2's should be fine for a daily driver and use them until i supercharge?
Old 07-26-2013, 06:45 PM   #8
Stage 2s are definetly fine for a dd.
Old 07-26-2013, 06:46 PM   #9
2300turboford's Avatar
+1
Old 07-26-2013, 06:50 PM   #10
Appreciate it guys.
Old 07-26-2013, 08:23 PM   #11
Stage 1s are Comp 262s and will install perfectly with 0 issues provided you degree them right. Will have a nice rumble at idle and you can get over 300whp with a 262 cammed car with all the bolt ons and a good tune.
Stage 2s are Comp 270s and you MIGHT be able to get away with installing them straight up in a stock PI motor but you also might have PTV issues. It will be VERY close. This can be remedied by installing them a few degrees retarded and they will 100% work in a stock PI motor as long as you or the installer knows what they are doing.
Old 07-26-2013, 09:04 PM   #12
Could I run the 262 cams in my bullitt with a non pi rotating assembly ? 270s ?
Old 07-26-2013, 10:53 PM   #13
So would it be okay to run the stage ones with forced induction? Or should i just wait and install the stage two along with f/i? Sorry for all the questions im new to cams.
Old 07-27-2013, 02:35 PM   #14
Its totally ok but you won't be able to make any more overall power than you would with the PI cams because of the limitations of the stock internals. You might have a better powerband while out of boost with the S trim but with a set of 4.10 gears you'll be able to get up in the higher RPM range pretty quick anyway.
I mean are you going to supercharge it in the near future or do you just have plans for in a year or two? I ask because plans for a year or two usually turn into longer or never lol. Been there a few times haha.
Old 07-27-2013, 03:19 PM   #15
Sonicblue11's Avatar
Will stage 2 cams make you lose any hp? More top end and less bottom end I would assume, correct me if I'm wrong
Sonicblue11 is offline   Reply With Quote
Old 07-27-2013, 03:44 PM   #16
Working on in the next few months...just trying to get all the bolt ons i want first and supporting mods so i dont need to keep custom tuning.
Old 07-28-2013, 08:14 AM   #17
H.Doofenshmirtz's Avatar
Region: Australia
An article i came across a few months back will answer this Q
https://www.dssracing.com/v/vspfiles...cam-motion.pdf
OP, give this a read too, and see how this jives with your long-term plans. If you're going to boost "eventually", when is that? You may want to consider doing the cams and f/i at the same time to get the right kind of setup for your application. Also, upgraded cams should send you the way of your nearest dyno to be tuned properly.
Good luck with your plans, hope it works for ya
COMP CamsĀ® - Sorry...
No work and no pony makes Doof a dull boy...
H.Doofenshmirtz is offline   Reply With Quote
Old 07-28-2013, 11:05 AM   #18
Thanks. The second link keeps saying an error occurred
Old 07-28-2013, 08:17 PM   #19
Region: Australia
odd....works for me but prolly cuz its local to my system...
h**p://www.compcams.com/Pages/419/camshaft-breakdown.aspx
if that doesnt work, basically its the comp cams site with a selector thingy (thats the technical term) for which cam would work for ya.
Old 07-28-2013, 08:19 PM   #20
Thanks man ill check it out
Old 07-28-2013, 08:20 PM   #21
Forgot about Hitec stage 2s which, IIRC, you do not have PTV issues with on PI heads/PI rotating assembly. I have never had any experience with them personally though so I'd do a google search.
Old 07-28-2013, 11:01 PM   #22
jjsg09's Avatar
Hitech is the highest producing stage 2 cam for the PI motors. Might not be the meanest sounding but will add some good hp for the money put into a project like this. Plus I think they are safe on stock valve springs as long as you keep it below 6200 rpms.
06:38 PM
