Do mach 460 amps have fuse? - Mustang Evolution
Old 07-26-2013, 12:42 AM   #1
calebnaasko's Avatar
I'm gettin no power from the amps
calebnaasko is offline   Reply With Quote
Old 07-26-2013, 09:10 AM   #2
1996mustang's Avatar
The fuse for the amp is in the engine bay. Fuse 13 for the right sidr and fuse 15 for the left side. Also check the fuses inside the car fuse 9 for the amps
Old 07-26-2013, 09:17 AM   #3
The ground to the amps is g403 located behind the trim panel lh side rear.
Old 07-26-2013, 09:26 AM   #4
02GTvert's Avatar
Had same problem one of my amps burned up bought a new 460 amp worked for a day and then had no power out of them..if one goes out the other wont work..at least in my case.
02GTvert is offline   Reply With Quote
Old 07-26-2013, 01:30 PM   #5
All fuses are fine from what I can see. I also can't find that ground anywhere
10:19 PM
