Squeaky front end - Mustang Evolution
Old 07-26-2013, 08:21 AM   #1
Squeaky front end
My 2000 squeaks when you turn the wheel? I have heard other Ford vehicles from this era mimic the same sound. Anyone else have this and what is a good bushing replacement to eliminate this irritating sound.
Saberstang is offline   Reply With Quote
Old 07-26-2013, 08:58 AM   #2
1996mustang's Avatar
Ball joints. Moog ball joints are a very hood replacement for them imo.
Old 07-26-2013, 10:24 AM   #3
Thanks for the tip, I didnt want to replace with OEM ford parts and have the problem return.
Old 07-28-2013, 04:53 AM   #4
taylor98gt's Avatar
Could be strut bearings as well mine was squeeky when I turned and I replaced them when doing my suspension and hasn't mad a noise since.
taylor98gt is offline   Reply With Quote
Old 07-28-2013, 07:43 AM   #5
There is also a squeak or creaking that it's known to come from the steering rack. There was a TSB released on that, replacement steering rack mounting bolt sleeves fix the issue I believe, I think they are like $12 from Ford.
Old 07-28-2013, 07:50 AM   #6
JayStang718's Avatar
I just had the same problem It ended up being ball joints but I realized that after I replaced the rack and the sleeves that the rack slides into smh
---------- Post added at 09:50 AM ---------- Previous post was at 09:48 AM ----------
I posted this on YouTube if u have the same exact noise it's ball joints
JayStang718 is offline   Reply With Quote
Old 07-28-2013, 06:20 PM   #7
Fred2000GT's Avatar
It was my ball joints as well. 2000 GT, squeked every time until I replaced the ball joints.
Fred2000GT is offline   Reply With Quote
Old 07-28-2013, 06:27 PM   #8
Yeah they say its our gen mustang that encounters it more but I heard in general fords have been known for faulty ball joints
Old 07-29-2013, 07:55 AM   #9
Thanks for the info guys. I have it in the shop, just have to get it in the air and start the process of elimination. I have heard the same sound from F-150's of the same gen. Must be a common problem with the late 90's/2000 Fords
06:55 PM
