Diesel sounding engine - Mustang Evolution
Old 07-26-2013, 01:06 PM   #1
So I just changed all cops and plugs but the misfire didn't go away. I rechecked my work and all seems good. The engine shakes slightly at idle and also sounds like a small diesel.
The youtube videos i've seen are way way louder than mine. Mine also smooths out with more rpms. Any ideas?
Might have to pull out the engine
Apex Predator is offline   Reply With Quote
Old 07-26-2013, 02:14 PM   #2
Billymich's Avatar
Exhaust leak?
Old 07-26-2013, 02:36 PM   #3
Count Dragula's Avatar
Mine was a bad injector
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 07-26-2013, 03:24 PM   #4
To me that sounds like timing chain slap against the timing chain guides. No after market cams or anything ? To rule out what was said above about the injector move the suspected bad injector from the cyn that's misfiring to another cyn. If the misfire swaps from one cyn to the other you found your problem.
southernstang00 is offline   Reply With Quote
Old 07-26-2013, 03:45 PM   #5
Checked injectors and they are in working order. Why couldn't the CEL just lit up!
Car drives but i rather not, exhaust sounds like crap. Calling it quits for today.
Old 07-30-2013, 02:40 PM   #6
Well I disconnected the battery for about 45 minutes and connected it again. Car is not making the noise and the misfire is now very minimal at idle only. Car drives smooth and has power. I believe the small misfire is due to do a leaking spark plug on cylinder 4 where i had a blow out a few months ago. Might just end up replacing the heads.
03:09 AM
