02 gt conv front brakes not releasing - Mustang Evolution
Old 07-26-2013, 05:39 PM   #1
front brakes on my 02 gt not releasing ,both sides could it be master cylinder or p. valve
c davenport is offline   Reply With Quote
Old 07-26-2013, 05:49 PM   #2
Billymich's Avatar
doubt its the p. valve
Old 07-28-2013, 10:05 AM   #3
jjsg09's Avatar
Start small, try replacing brake lines. But try to get a good deal on braided lines.
Old 07-28-2013, 04:37 PM   #4
strange69's Avatar
I had a similar problem with my rear brakes and it could be the slide on the caliber bracket is ceased and not allowing the caliber float properly about a 20 fix for the hardware if you can salvage the bracket if not maybe 60 the most! Good luck
strange69 is offline   Reply With Quote
Old 07-28-2013, 04:45 PM   #5
Slide pins X1000. Replace them and you should be good. Common problem on Fords.
Old 07-28-2013, 06:15 PM   #6
Fred2000GT's Avatar
Definitely replace your slide pins. This happened on my 2000 GT before I put it in storage. Replaced pins and good to go.
Fred2000GT is offline   Reply With Quote
Old 07-28-2013, 08:43 PM   #7
Blogger
99ford's Avatar
Very good possibility but start with calipers if that doesn't solve the problem replace the master
Old 07-28-2013, 09:32 PM   #8
strange69's Avatar
If you gonna do calipers start cheap and then go up " caliper rebuilt kits " $25 as appose to $165
Old 07-28-2013, 10:40 PM   #9
If you're going to do calipers get some Cobra/Bullitt/Mach units and upgrade to 13" fronts.
Old 07-28-2013, 10:49 PM   #10
jjsg09's Avatar
Yes +1,000 if you have the money just do this.
04:05 PM
