Mustangs been sitting for a Year! :( - Mustang Evolution
Old 07-28-2013, 12:05 PM   #1
Mustang_Madness's Avatar
However, I have a new engine and I'm about to swap the parts over to it to drop it in. But, my question is: What should I look at because it's been sitting? I'm going through the tank and fuel lines before i start it up, but what else should i look for?! I'm getting real close to get it up and running.. Just on the home stretch and need to finish up! Thanks for the help yall!
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 07-28-2013, 01:37 PM   #2
Definitely clean fuel lines and tank. Other than that with dropping a new engine I imagine you are adding all New fluids, I.e. coolant and oil.
Might drain and fill tranny with fresh fluid while you're at it.
Old 07-28-2013, 04:15 PM   #3
My 95 Cobra sat for longer than that... bad time in my life... Anyway fuel filter, all new fluids and probably a good idea to do the brakes/bleed them. Tires might have flat spots if you haven't been moving it back and forth.
Old 07-28-2013, 06:13 PM   #4
thanks guys! I am definitely flushing All the fluid and its been moved around a bit so no flat spots thankfully. But I think ill do the brakes. No point in messing something up later ya know? Also can you check out this CL link? I need to know if thats a good deal. I have the clutch out already so im thinking of getting it! Thanks a bunch!
New Stage 2 exedy clutch kit 99-04 mustang gt
---------- Post added at 07:13 PM ---------- Previous post was at 07:13 PM ----------
I have a 96 mustang with a 98 V8 in it. can i still use it if its 99-04?
Old 07-28-2013, 06:17 PM   #5
Fred2000GT's Avatar
My car sat for 18 months and even with a good engine, it just won't start. So if you left gas in it, you might want to check/replace the fuel pump while you're at it cleaning the lines and tank. Just in case.
Fred2000GT is offline   Reply With Quote
Old 07-28-2013, 06:18 PM   #6
The dude on there needs to let you know what flywheel size he bought it for. up to 01 they used 10.5" flywheels, from 01.5-up they used 11" flywheels.
Your car SHOULD have a 10.5" flywheel in it and I'd honestly get this kit.
Old 07-28-2013, 06:22 PM   #7
Fred2000GT's Avatar
I'd buy it!!
Old 07-28-2013, 06:58 PM   #8
Ill ask this guy about it and if it is a 10.5 how can i find out that mine is a 10.5? I have it out, so is it etched in it or something??
Old 07-28-2013, 07:03 PM   #9
If its out of a 98 it is a 10.5" setup. Or you can measure...
Old 07-29-2013, 10:16 AM   #10
Ill definitely look into it man. Thanks!
Old 07-29-2013, 10:22 AM   #11
I had mine in storage for a little over 3 years! New fluids, check rubber for dry rot and dry gas if the tank was under 3/4 full and the car was not in climate control storage.
Saberstang is offline   Reply With Quote
Old 07-29-2013, 08:37 PM   #12
So should i dump my gas? Or what? Think it's still good?
Old 07-29-2013, 11:17 PM   #13
Slow4V's Avatar
Dump it for sure
Old 07-30-2013, 08:03 AM   #14
If your tank isn’t full and was not in a controlled temperature the chances of condensation forming are high, especially with the added ethanol in today’s gas. I didn’t drain mine as I have a CC storage facility with Lucas fuel treatment and I could tell that I should have drained the fuel! Your judgment call…
Old 07-30-2013, 10:06 AM   #15
351stroker's Avatar
Drain your fuel. Fuel nowadays had a short shelf life. It starts to go bad fast. Smell in the tank is it sweet? Not to mention the possibility of corrosion or some crud settling in the tank. Just drop it an drain it. Do yourself a favor when u have it out and put in a bigger fuel pump.
351stroker is offline   Reply With Quote
Old 07-30-2013, 11:38 AM   #16
CodyNelson's Avatar
Region: West Virgina
When you do the brakes be sure to drain all the fluid and flush the system. I just spent the weekend putting on all new calipers, pads, lines, and hoses because I never thought to change the brake fluid. Brake fluid can boil as your brakes are used and the boiling releases condensation in the line that will cause you one heck of a nightmare. I never through $10 of brake fluid and an hour to bleed everything could save $650+ in a completely new brake system (minus master cyl)
Old 07-30-2013, 12:47 PM   #17
Great info guys! i will definitely dump the gas then, as well as look for a bigger fuel pump. what size should i be looking at? I have aspirations for making this Stang over 500 rwhp so should i just grab a big enough fuel pump for that or just grab a bigger one than stock for now? Also I will do everything i need to do with the brakes. new fluid and all. Its been covered but outside in the snow and rain and sun, so Whatever I need to do to have it working properly, I'll do. This is great though! Awesome info
Old 07-31-2013, 09:42 AM   #18
351stroker's Avatar
255lph fuel pump or bigger should support what u want.
Old 07-31-2013, 10:31 AM   #19
Good choice.
Old 07-31-2013, 10:35 AM   #20
Fred2000GT's Avatar
+1
11:43 PM
