03 mustang gt no start - Mustang Evolution
Old 07-28-2013, 06:43 PM   #1
I have a 03 mustang gt. Just installed new intake and car just cranks and cranks but no start. Oil smells little like gas. And if it does start it barel . Turns on real rough and dies out right away. White smoke from exhaust. . I know its either a spark or fuel issue. Anybody have any advice what it could be. Ive been two days breaking my head.. thanks
03mustanggt is offline   Reply With Quote
Old 07-28-2013, 07:24 PM   #2
Does anyone know the location of the schrader valve on 03 gt. Checked spark plugs and few of them came out looking real black soot looking. Brand new plugs. Two days old. Seemed like it was too lean but still cant get the car to fire up and idle. Any ideas. Please let know.
Old 07-28-2013, 07:39 PM   #3
Slow4V's Avatar
Manifold ?
Old 07-28-2013, 07:45 PM   #4
I installed brand new intake manifold. But now no start..
---------- Post added at 06:45 PM ---------- Previous post was at 06:45 PM ----------
Im thinkin its a fuel or spark issue??
Old 07-28-2013, 07:48 PM   #5
Slow4V's Avatar
White smoke is a manifold leak for sure .. Coolant , I'd retrace everything you did , sounds like its not on right or maybe gaskets came off
Old 07-28-2013, 07:53 PM   #6
Well gaskets couldnt have come loose. There is no coolant leaking out. The gaskets have a rubber like button that falls in hole to stay. In place. Im just tryimg to get it going cause its getting frustrating. When i took off old intake some coolant might have got in the cylinder holes. Do you think that could cause a no start..?
Old 07-31-2013, 08:12 AM   #7
Michael.s.king's Avatar
Region: Maine
Is it a cold air intake you just installed? My brother just put one on his 2000 gt and it was having trouble to start. We figured it out and he didn't put the intake air temperature sensor in his new intake. Might be worth a look
---------- Post added at 10:12 AM ---------- Previous post was at 10:11 AM ----------
Just re read your original post and his car ha the exact same trouble starting as you described
Michael.s.king is offline   Reply With Quote
Old 07-31-2013, 08:31 AM   #8
Fred2000GT's Avatar
It depends on how much coolant you think might have dropped into the cylinders. I just replaced my entire air intake manifold to the one that doesn't crack like the old ones did. I wouldn't press the gas when trying to start the vehicle either. Since you smell gas, you might be flooding the engine with gas/coolant mixture which could cause the spark plugs to have a black soot type appearance as well as hard time starting the car.
All coolant burning is white. So chances are you might have gotten a good amount of coolant into the engine.
---------- Post added at 07:31 AM ---------- Previous post was at 07:29 AM ----------
Oh, mine is a 2000 GT which is the same exact design as yours
Fred2000GT is offline   Reply With Quote
Old 08-02-2013, 01:40 PM   #9
1996mustang's Avatar
Take out all your spark plugs. Remove the relay for the fuel pump or fuse for it and remove the fuse for the coils or ignition module. Then crank the car and see if anything comes out of the spark plug holes like coolant or fuel. You could have an open injector or a coolant leak from the manifold. Or possible flooded motor due to coolant from the last manifold. Either way its to empty out the cylinders of anything that could be in it to begin. After try to start it reinstalling everything u removed and check to see if it starts normally
11:38 PM
