Squeaking sounds - Mustang Evolution
Old 07-30-2013, 07:28 PM   #1
Francis's Avatar
Squeaking sounds
I hear a squeaking sound when I hit bumps, checked exhaust and everything is nice and tight. Would bad shocks make a squeaking sound if they was bad.
Francis is offline   Reply With Quote
Old 07-30-2013, 08:00 PM   #2
ChrisD522's Avatar
I have an 01 GT with the same problem. I'm thinking it's either the shocks or springs. Haven't had much time to look at it though
ChrisD522 is offline   Reply With Quote
Old 07-30-2013, 08:07 PM   #3
1996mustang's Avatar
Control arms is my guess. Does it squeak while turning or just on bumps?
Old 07-30-2013, 08:22 PM   #4
Francis's Avatar
I took it to Midas and they said my shocks and stuff looks pretty good, think I might take it somewhere else and see what they say
---------- Post added at 09:22 PM ---------- Previous post was at 09:21 PM ----------
Just bumps
Old 07-30-2013, 08:26 PM   #5
Imo its the control arms. Fo a simple test. Go to your car put your hands on a fender and bounce the car a couple of times. If its squeaking chances are more than likely its the control arm busings. Do both if your gonna do them.
Old 07-30-2013, 08:29 PM   #6
Francis's Avatar
They done that when I took it to Midas and they couldn't hear the sound at all
Old 07-30-2013, 08:49 PM   #7
Sometimes they just push on it to see the shocks. I jumped on mine somewhat to find mine lol. I dont recommend u to jump on yours lol but what i meant was i had the door open and i stood on the door step and jumped up and down
---------- Post added at 10:49 PM ---------- Previous post was at 10:48 PM ----------
Its always good to get another opinion from another shop see what the other one tells u plus is it from the front or rear the squeak
Old 07-30-2013, 08:50 PM   #8
Francis's Avatar
Maybe I will try that tomorrow and see what happens
---------- Post added at 09:50 PM ---------- Previous post was at 09:49 PM ----------
Sounds like its coming from both rear and the front lol
Old 07-30-2013, 10:06 PM   #9
Coltonhess's Avatar
I have the same problem and its most likely the control arm bushing. That's what I've narrowed it down to because I replaced shocks and it still does it. However the side it's making the noises from the exhaust hits the axle on big bumps.
Coltonhess is offline   Reply With Quote
Old 07-30-2013, 10:29 PM   #10
Boomdizzle's Avatar
My vote is for control arm bushings. My fox body used to squeak all the time until I either replaced them or sprayed them with lubricant all the time lol
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 07-31-2013, 08:41 AM   #11
Fred2000GT's Avatar
I have a 2000 GT, all 99-04 mustangs are known to make that annoying sqeaking sound once it's been driven for some years. I replaced the shocks, struts, struct brackets which hold them in place and still sqeaks. I replaced the control arm bushings and a miracle!! No more sqeaks!!! At least not for a couple years anyways. LOL
Fred2000GT is offline   Reply With Quote
Old 09-04-2013, 07:04 AM   #12
Francis's Avatar
Squeaking sound was actually a rattling sound, found out it was my clips that hold my brake pads in place was worn out, which was making my brake pads shake when I was hitting bumps
05:58 AM
