In the market for a GT! - Mustang Evolution
Old 07-31-2013, 01:54 PM   #1
twotone01's Avatar
Well I just sold my 01 sixxer and looking for a GT now, price range is up to about $4500, I'm in souther California and have found a lot of nice looking ones. But I'd like to know if there are curtain things that I should look out for. I had the sixxers down, but not so much the GTs
Thanks!
twotone01 is offline   Reply With Quote
Old 07-31-2013, 02:25 PM   #2
Thanks!
Same thing just a lil more powerful.
Torchred2010gt is offline   Reply With Quote
Old 07-31-2013, 02:27 PM   #3
twotone01's Avatar
I meant like things I should look out for when buying haha shouldve been a little more clear about what i meant,
like I hear the rear main seals sometimes leak is there anything else I should look into?
Old 07-31-2013, 04:24 PM   #4
You should look out for EVERYTHING. The "newest" New Edge that you will find is going on ten years old. The fleet is ageing...
Old 07-31-2013, 05:11 PM   #5
1lowGT's Avatar
Check everything you can see. Rear end and under the hood.
---------- Post added at 06:11 PM ---------- Previous post was at 06:10 PM ----------
Once bought you should freshen it up with new plugs and fluids change.
Old 07-31-2013, 11:37 PM   #6
Slow4V's Avatar
Thanks!
Cracked intake manifold , mainly near the thermostat , and back where heater hose goes..
Throw out bearing noise
Rear end movement or noise ( Control arm bushings going out )
Front timing cover leaks
And just the usuall.. Cracked dash, if seat works .. Especially if AC works ..
10:14 PM
